Old 07-12-2014, 05:53 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Ac vibration and aound when starting car and lwtting it just idle?
I posted a thread earlier please disregard it. Issue is when i start the car up and have ac button on and xold air the car will make a vibration and loud noise. Turn it off it goes away. Always stops with ac on after intial driving of the car. Any clues to what this may be. I find it odd only happens on cold start and idling at first but then goes away. I would appreciate any help on this
Frs32907 is offline   Reply With Quote
Old 07-12-2014, 07:02 PM   #2
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
If you mean rattling then try pressing on the clutch pedal when it's a cold start then see if it goes away, if it does then it's normal, the clutch usually makes most of the noise at cold startups other than the engine.
Yamajee is offline   Reply With Quote
Old 07-12-2014, 08:59 PM   #3
Frs32907
Nope doesnt matter if clutch is engaged or not. It is directly related to the max ac button being turned on at start up and idle. Its almost like a shaking
Old 07-13-2014, 06:32 AM   #4
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Here is the TSB on this.
ntron1 is offline   Reply With Quote
Old 07-15-2014, 08:18 AM   #5
Frs32907
Bot sure thats the issue..
Old 07-16-2014, 02:34 PM   #6
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
it dips bad w AC on, the tsb helps a lot but doesnt alleviate the issue completely.
also, they literally just dump more gas in the chambers.
nos145 is offline   Reply With Quote
Old 07-16-2014, 02:53 PM   #7
Frs32907
The rpms dont dip i have the lasted ecutek update. Basically it sounds like a thump that goes away once you drive and then stop again.
Hood Vibration Question shinbatsu BRZ First-Gen (2012+) — General Topics 10 07-02-2023 07:06 AM
2600rpm vibration stueck9356 Issues | Warranty | Recalls / TSB 3 03-06-2014 12:06 PM
uneven engine vibration at idle whtchocla7e Issues | Warranty | Recalls / TSB 17 08-07-2013 09:21 PM
Speaker Vibration JayNutter Electronics | Audio | NAV | Infotainment 12 07-31-2013 12:24 AM
Reverse lockout vibration SubaSteve Issues | Warranty | Recalls / TSB 4 03-23-2013 01:26 PM
