Drives: 2013 FR-S Hot Lava
uneven engine vibration at idle
Does anyone else, with a stock car, experience uneven engine vibration at low idle rpms?
After a cold start, my car runs a little rough for a bit and then smooths out gradually. When the engine settles below 1k rpm,I sit and listen for odd things and I can feel unevenness in engine vibration transmitted through the floor to my legs and the seat. No fluctuation detected on tach. I'm not talking about the CEL rough idle phenomena. Could someone pay attention to this next time you get in the car and report back?
Live to drive another day
Drives: Sterling BRZ Ltd
Ive been noticing weird vibrations, both at idle and at constant highway speed.
Have you ever owned a Subaru before? The cars don't idle all that smoothly and some vibration is normal when idling. Vibration at highway speed is something different.
Drives: 2004 WRB STi | 2013 GBS BRZ
I've noticed this aswell. Never felt anything like this and I've owned an sti for years now.
2013 BRZ | 2004 WRX STi |
Drives: Ultramarine FRS 6MT
I have the same experience with my car. It's not the smoothest idling engine. It feels like as if the engine skips a beat sometimes and I feel it through the chassis.
Drives: GT86
Mine does the same, worse when colder outside.
When the engine warms up it does not vibrate at all through the chassis. But on cold it feels like som old american v8
Yup owned an STI for a few years.
Is your A/C or defroster on? That explains like 90% of the rough idle complaints.
Drives: Subaru BRZ
I feel it when idling sometimes, hope it's normal for a boxer...
#10 |
Drives: 86
any updates on this ?
#11 |
Drives: SWP Subaru BRZ
I believe everyone has this feeling. I asked the first time I sat in my car because it felt as if it was moving side to side. Much like slapping the left then the right inside the engine bay. I had never dealt with a Flat Four engine before and was always used to my Honda motor. Basically from what other people I know that own Subaru's, it is perfectly normal. I can only imagine the light weight factor of this chassis only exaggerates the motion of the Flat Four motor.
#12 |
I've really started noticing it on mine over the past couple months (shorter commute, more stop and go while cold), seems like it's just a Subaru thing, you're not as isolated from the motor like most Honda's and Toyota's.
#13 |
So would these symptoms be normal? At least for the start up?
#14 | |
Drives: Subaru BRZ Sport Tech Satin White
Flat crank V8 (think Ferrari ) are better balanced than normal bent crank V8 but still have firing order vibrations. |
| Engine idle chirping (cricket) noise poll. | Hanzo | Issues | Warranty | Recalls / TSB | 5031 | 05-18-2017 09:41 AM |
| Strange noise/vibration under heavy engine load | Panecki17 | Issues | Warranty | Recalls / TSB | 65 | 05-04-2017 07:58 AM |
| Engine idle chirping (cricket) noise poll. | Hanzo | BRZ First-Gen (2012+) — General Topics | 229 | 02-16-2016 01:21 PM |
| Engine shaking/vibrations at 1700rpm - when in neutral/idle | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 11-07-2013 10:00 PM |
| Speaker Vibration | JayNutter | Electronics | Audio | NAV | Infotainment | 12 | 07-31-2013 12:24 AM |
