| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
is better than you
Drives: 2013 raven FRS
So i broke my wheel speed sensor
Idk which wheel, but at a track day today i went off into the dirt fairly hard, broke the sensor and hopefully only my alignment and nothing suspension related since my steering wheel is crooked now. Are the speed sensors dealership only? If so how do i replace them? Are they just plug and play?
#2 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I had to replace one on my sti before and it was plug and play. Imagine it shouldnt be too different. And yeah, dealer only. Best bet is prob online since the dealer is gonna have to order it anyway. |
| The Following User Says Thank You to finch1750 For This Useful Post: | bkblitzed (11-30-2013) |
#3 |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
You can order them online from a oem parts dealer (ie. 1stToyotaParts.com) and they're $103.97 each.
SU003-00663 - Front LH speed sensor SU003-00662 - Front RH speed sensor SU003-00665 - Rear LH speed sensor SU003-00664 - Rear RH speed sensor
SC10N FR-S #435 of 2500
#4 | |
is better than you
here's a pic of the steering wheel
#5 |
*****istrator
they're actually cheap imo. i'm used to them being around $150-$200 each for my previous toyotas.
anyway, your first step is to read the code and find out what exactly is causing the ABS light to appear. it's probably just a torn ABS wire.
#6 |
is better than you
the lights turned off today, im guessing they can be reset within a certain amount of cycles? I could turn off trac and vsc. So im guessing its only an alignment issue
#7 |
Drives: 13 White MT FR-S
I got off ebay for like $40, and it just plugged right in.
#8 |
is better than you
#9 |
I had to read this a couple times to understand why your toe was fucked up...need more caffeine. thats crazy though.
#10 |
Time Traveller
Necro.... How long did you have to drive it before the light went off after changing the sensor? When you were driving the car was it in limp-home mode?
| Speed Sensor Bases Limp mode after new tires | MrSlay | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 03-30-2018 11:31 PM |
| Fuel pump and speed sensor | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 28 | 04-20-2017 02:54 PM |
| Noise when turning steering wheel at low speed | Slant | Issues | Warranty | Recalls / TSB | 7 | 11-06-2015 09:53 AM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 07:39 PM |
| Recommendations to a speed/wheel/tire shop around orange county?? | eddieEndo | Southern California | 6 | 02-10-2013 08:36 AM |
