Getting A Better Ride, or how to setup and adjust your Airlift struts
Hi to all you airlift bagged FRS, GT86, and BRZ drivers! This thread is about how to setup and adjust Airlift suspension, Not an invitation for Hater bashing. I drive my BRZ as a work car doing onsite computer repair.
I also use my BRZ to tow our kayaks. Life's too short to drive a hybrid, or any other car which is no fun. Occasionally I have to drive up steep driveways and even steep unpaved driveways/roads. I normally drive at stock height and raise it up for clearance as needed. So, what is your normal ride height, and what dampening settings do you use? Last edited by KoolBRZ; 07-09-2014 at 01:45 PM. Reason: change pictures |
| The Following User Says Thank You to KoolBRZ For This Useful Post: | diirk (07-08-2014) |
Drives: ZC6, Junk of ALL sorts
This is awesome!
# 1. Always know where your towel is.
ZC6-CBS, is home |
#4 | |
Front - 25 clicks from full hard Rear - 26 clicks from full hard I'll measure the height later and post that as well. |
| The Following User Says Thank You to KoolBRZ For This Useful Post: | Jyn (07-07-2014) |
#5 | |
Noob
Drives: FR-S Mammogram
Drives: BRZ / MX5 / S4
The idea of an airbag suspension seems really interesting to me, although I'm just not sure how it would realistically hold up to winters/salt/etc.
Drives: 2014 GB Scoobie BRZ
my range rover bags lasted nearly 16 years before i replaced a single one, I'm sure it will be fine.
I got pictures!
I got pictures!
| The Following User Says Thank You to KoolBRZ For This Useful Post: | diirk (07-29-2014) |
Boosted
Drives: Sideways
I'm curious about getting airlift setup. I really really don't know much about it.
Is it able to drop the factory ride height at least 2"? - Would it be able to withstand track time? Or is this purely cosmetic? Can it raise the factory height at least 1-2"? - My car gets towed every now and again due to miscellaneous failures due to having high horsepower. My bumper scrapes as it is right now getting onto tow trucks. Thanks
#10 | |
Drives: 4Runner
Would it be able to withstand track time? Or is this purely cosmetic? Several of the systems are trackable including AirLift and AirRex Can it raise the factory height at least 1-2"? Yes. 1" is possible. More can be attained. These have coil-overs are part of the system, so it all depends on your initial height setup.
diirk
waiting on a Neptune Premium MT |
#11 |
Drives: 2014 Subaru BRZ
Question on the initial height setup. So you can set it up that when the car is parked, it can be 2" from stock only. Then driving around 1" lower from stock. Then can raise it more than stock?.
Reason I ask is I dont want to slam the car. Only reason Im interested is for winter purposes.i've been stuck a couple of times already this winter coz the car is just low. Thanks so much! |
| Airlift on the track? | mkivalex | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 06-16-2022 03:58 PM |
| Airlift Air Suspension for BRZ/FRS get down low!!! | Gruppe-s | Brakes, Suspension, Chassis | 21 | 11-25-2014 09:10 PM |
| airlift suspension? | kendalldwhite | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-07-2014 10:56 PM |
| Airrex VS AirLift? | iJason | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 09-04-2013 08:55 PM |
| Anybody Running Airlift Suspension | Admired | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-04-2013 12:30 PM |
