Old 09-04-2013, 06:45 PM   #1
iJason
Drives: Scion FRS Raven Black
Exclamation Airrex VS AirLift?
Title.
AirLift has more dampening control.. I don't know. Pros? Cons? Help!
Also; this part kind of belongs in the wheels section but if I get bagged, will I have a problem if I get the following wheel specs?
F: 19x8.5 +33 - 225/35/19
R: 19x9.5 +43 - 245/35/19
I want no fender rubbing and no pulling/rolling. If those don't work, I'll just have to go smaller.
As for the negative comments about bags; unless you've give the performance tuned bags for the FRS/BRZ a drive, keep them to yourself.
iJason is offline   Reply With Quote
Old 09-04-2013, 06:50 PM   #2
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by iJason View Post
Title.
With some camber while lowering, you shouldn't have rub issues.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
iJason (09-04-2013)
Old 09-04-2013, 07:24 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
More damping control is better, IF it's effective. I'm not familiar with either kit, do they use the compressed air for the damping, or oil like a conventional shock?
Effectively, and predictably adjusting the flow of oil inside a conventional shock, in an effort to adjust the damping rates, with a needle valve is excruciatingly hard. The tolerances for the valves have to be ridiculous. If the air setups are using air as there damping medium aswell, this would orders of magnitude harder.
Old 09-04-2013, 07:25 PM   #4
iJason
I don't think I'll be cambering.. In the winter I want my tires as flat as possible. It's RWD obviously, so sliding could become an issue. I suppose I'll have to go smaller then?
Old 09-04-2013, 07:28 PM   #5
Calum
That Guy
Just put your winter tires on your stock rims. You don't want that wide of a tire for snow anyway.
Old 09-04-2013, 07:42 PM   #6
iJason
I don't have winter tires
Suggestions?
Old 09-04-2013, 08:34 PM   #7
Calum
That Guy
Suggestions?
Goodyear Nordic. They're cheap as hell, but they'll last about four winters, and they work. I'd imagine your winter conditions are similar to ours, some ice, but mainly snow and slush that's hard to clear from the tread of the tire. If so, these are great.
What they don't do is anything performance orientated.
If you're looking for a performance winter tire, you'll have to ask someone else.
The Following 2 Users Say Thank You to Calum For This Useful Post:
iJason (09-04-2013), superiorx120 (08-25-2014)
Old 09-04-2013, 08:55 PM   #8
iJason
Cheap is good haha. Bags will cost me a little over 4 grand. Plus new rims and camber plates, along with the 19" tires for my summer wheels. That's as much bloodsucking as my wallet will take for now. & I'll have the stock rims that I'll stick on those goodyears.
airlift, airrex, stance, suspension, wheels
Anybody Running Airlift Suspension Admired Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-04-2013 12:30 PM
AirREX FT86 Project eight08customs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-14-2013 05:44 PM
AIRREX/ FIVE AD Project FRS eight08customs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-09-2013 04:49 AM
AirRex Wireless Suspension just86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-27-2012 10:30 PM
