Old 06-30-2014, 01:46 PM   #1
JordanLawrence
Drives: 14 BRZ
So how hard is it to do an LS1 swap
Like the title says, realistically how much harder is it/more expensive is it going to be to go that way over a turbo with an engine costing around 3-3500. What other modifications will I need to do (ex. rear diff) Just curious...
JordanLawrence is offline   Reply With Quote
Old 06-30-2014, 02:03 PM   #2
Diode Dynamics
Diode Dynamics's Avatar
Welcome to the forum!
I suggest doing a search to gather more information. This has been discussed a few times on the forum
It's definitely going to be more expensive then a turbo upgrade
Nick C.
John C.
Diode Dynamics
Old 06-30-2014, 02:04 PM   #3
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Are you an automotive technician? Do you have a shop? How are you with fabricating? Wiring?
To my knowledge there aren't any LS swap kits yet. (dont quote me on that) This means you would be responsible for creating everything. I'm currently working on an S-chassis LS swap and there are drop-in kits/s-chassis to chevy wiring everywhere. Its going to cost me around $3000 for a "junkyard build". With out any wiring/mounts/custom oil pans/drive shafts on the market yet. You are looking at a lot more than that plus custom fab. Get a hold of one of the Techs at a formula drift competition and ask them. They are FULL of knowledge and love talking cars.
If you must have more power just supercharge the FA20. 240 HP with an innovate supercharger for less than $3000 and close to ZERO custom fabrication sounds great to me.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 06-30-2014, 02:46 PM   #4
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Weapons grade made a swap kit. I think it was runing around 15k$ (don't quote me) just for the kit. No cutting/welding, labor, engine, or trans. I'm not sure about the standalone either.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 06-30-2014, 02:54 PM   #5
sluflyer06
Drives: 2014 BRZ Ltd - DGM
But a stock LS motor will be both fast and reliable vs blowing up the FA20 with forced induction.
OP Also and I have no idea how easy or hard to swap but you can get a really low miles Coyote (2011+ mustang) engine for under 3 grand if you get it out of a F-150, the only thing to change it back to the mustang motor is the intake cams. There's a slight compression difference but not enough to warranty the price difference.
source: friend is in the middle of trading out his fully built and kenne belle 4.6L for a 5.0 motor in his track car.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 06-30-2014, 04:02 PM   #6
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
With a nice bolt on kit with all the needed accessories (cooling, ac/heater, fuel, wiring/electrical, headers, exh, driveshaft, making steering linkage and abs compatible if needed, ecu, etc) needed ($8k), LS3 crate engine ($6k), brand new tranny that fits perfectly (Magnum XL) with clutch and flywheel ($4k)....$18k for a brand new engine/tranny setup..give or take a few thousand for anything missing or the unexpected that may come up..so round up maybe an extra $2k..giving you $20k for all parts. Labor, do it yourself (which should be pretty easy since it's bolt-on and no welding/fabbing or engine block/tranny rebuilding experience needed)..or have a shop do it for $5k.
So for a proper, super nice and clean, brand new swap...$20k DiY ...or $25k if a shop does it.
Imo, and for the budget conscious, it is def not worth it to do it to a relatively new FRS/BRZ (it would be $28k for the car and $25k for the swap...bringing you to the same cost as a brand new corvette at $53k and other great cars in that range...not to mention, those cars will be made for the LS(or whatever else engine it came with) in terms of stronger chassis, bigger wheels/tires with suspension specifically made for that chassis and powerful engine) ....but totally worth it down the road instead of buying a new car. Maybe do it 5-15 years down the road, when the FA engine gets old, past 100k miles and/or blows up.
fooddude is offline   Reply With Quote
Old 06-30-2014, 04:14 PM   #7
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I'm pretty sure its a direct fit
Old 06-30-2014, 04:17 PM   #8
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
All you need is a parking spot, a hammer and about 30 minutes...
Kostamojen is offline   Reply With Quote
Old 06-30-2014, 04:18 PM   #9
JasperNoone
Drives: Car
Base kit $3750, complete kit $8000...add engine and trans. From their website:
Finally give your BRZ/FRS/FT-86 the power it deserves! Our World Exclusive BRZ06 / FR-SS LS Powertrain swap kit has everything you need to swap a 400hp+ V8 into your Subaru BRZ or Scion FR-S!
We offer two variants of the kit, a base version, and a complete version.
The base version consists of:
-Engine and Trans Mounts
-Driveshaft
-Oil Pan
-Clutch Master Cylinder
The complete version adds on to this package with:
-Cooling Components
-Fuel System
-Wiring/ECU upgrades to OEM components
-Exhaust System
-A/C and Heat Components
All kits are made to order, and certain components are modified using parts from your drivetrain of choice and will require shipment to us.
We also offer in house installation of the complete package for $5000.
JasperNoone is offline   Reply With Quote
Old 06-30-2014, 04:26 PM   #10
evan
Drives: fr-s
Trade it in for a Camaro SS.
evan is offline   Reply With Quote
Old 06-30-2014, 05:56 PM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
http://www.ft86club.com/forums/showthread.php?t=10401
http://www.ft86club.com/forums/showthread.php?t=61862
http://www.ft86club.com/forums/showthread.php?t=117
http://www.ft86club.com/forums/showthread.php?t=53534
http://www.ft86club.com/forums/showthread.php?t=45827
Old 06-30-2014, 07:46 PM   #12
continuecrushing
OMG, the OP said LS1, and then you post up 2 threads about LS2...
Now there's gonna be a "How hard is it to do an LS2 Swap" thread
Old 06-30-2014, 08:05 PM   #13
D K
Stig's dark passenger
I read on jalopnek that the LQ9 and LS7 are much easier conversion.
Also, on pinterest it says you can use factory ECU
D K is offline   Reply With Quote
Old 06-30-2014, 09:39 PM   #14
Captain Snooze
Drives: Red Herring
about LS2...
Yeah,I noticed that when scanning the posts but I thought I would throw those in because LS2 > LS1.
LS2/LS>LS1/LS
1x2>1x1
2>1
qed
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Hard choices pearsor1 BRZ First-Gen (2012+) — General Topics 24 02-24-2014 07:41 PM
How hard is it really? Kimsey47 Issues | Warranty | Recalls / TSB 13 08-16-2013 11:01 PM
Was I being hard on my car? Fr-s13 Scion FR-S / Toyota 86 GT86 General Forum 49 07-04-2013 09:54 PM
The hard part is done! koteman Other Vehicles & General Automotive Discussions 27 10-11-2012 01:02 PM
