Old 06-28-2014, 01:22 AM   #1
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
DIY request: Gauge install and wire routing
I hate posting new posts when one already exists but I searched this forum for a while yesterday and couldn't find anything. I'm deployed and when I get back I'm going FI, but I'm trying to do my research now so I can hook up the gauges, clutch and anything else I can do myself before I get back so I will have an easier time with the install. Where have all of you guys been running your wires for your gauges? I'm looking to do a super clean install, the gauges I'm going to be using are an AEM Failsafe, Innovate Motorsports Oil temp/Pressure and Innovate Batt Volt/Water Temp. I already bought an ATI Vent Gauge Pod, DCW Gauge Pod, and a steering column gauge pod, so the routing should be fairly easy I just wanted to see how you guys did it before I screw it up by myself.
mikepaul21 is offline   Reply With Quote
Old 07-04-2014, 03:06 PM   #2
jcw99
Drives: swp mt '14 brz premium
Look at Autometer's BRZ-Scion FR-S installation for some tips. Also see Lunatic's nice gauge install in the DIY section. Thank you for your service and hope you're having a good 4th of July!
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
mikepaul21 (07-05-2014)
Old 07-05-2014, 05:57 AM   #3
mikepaul21
mikepaul21's Avatar
Thank you so much, Autometer's site was exactly what I was looking for.
Old 07-05-2014, 12:43 PM   #4
jcw99
Nothing beats going down the road with a good set of gauges staring back at you! Plus you learn how to work upside down with your head jammed under a dashboard--and then your phone rings.
Freeman (09-16-2014)
Solved: Running 4-gauge power wire to trunk B-R-Z Electronics | Audio | NAV | Infotainment 3 11-08-2017 04:47 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
Routing wire to front doors lsr78 Electronics | Audio | NAV | Infotainment 5 09-15-2013 10:19 PM
Innovate Install Help - Vacuum Routing swift996 Forced Induction 36 07-15-2013 07:47 PM
wire routing for door speakers derka-derka Electronics | Audio | NAV | Infotainment 6 12-13-2012 09:49 PM
