Old 08-13-2013, 01:19 AM   #1
lsr78
Drives: 2013 Scion FR-S MT Ultramarine
Routing wire to front doors
Anyone have a special tip to get new speaker wire through the door grommets? The s shape makes them quite difficult. Tried a bent coat hanger with no luck.
Perrin Non Res Cat Back/CAI/Inlet/Tranny Mount/Shifter Bushing
Enkei PF01
18x7.5 et38/Conti DW 225/40/Eibach Pro-Kit
H&R spacers 15mm rear/5mm front/Whiteline PSK/ECUTek Tune
Alpine IND-S920HD/MRX-V70/CDT HD-62/JL StealthBox/Bel RX65/JPM Coachworks interior bits
lsr78 is offline   Reply With Quote
Old 08-13-2013, 01:47 AM   #2
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
add pins to the plugs in the doors on both sides!
Sbeezy is offline   Reply With Quote
Old 08-16-2013, 03:24 PM   #3
BigJyoungblood
Enthusiast
BigJyoungblood's Avatar
Drives: 2013 Scion FR-S (37J)
Pull both plugs out on each side, scrunch them together to make it shorter and straight, then use a coat hanger or a long screw driver.
BigJyoungblood is offline   Reply With Quote
Old 08-17-2013, 03:06 AM   #4
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
is there a trick on how to put back the grommet back on the plastic on the fram of the car? It seems like i have to pull the plastic out a little bit and place it behind it.
Furtive is offline   Reply With Quote
Old 09-15-2013, 06:34 PM   #5
DeOppressorLiber
DeOppressorLiber's Avatar
Drives: FRS Full Blown Custom
The trick is to remove the grommet on car side then the white plastic piece from the car by pressing the tabs in with a screw driver or pick and then putting the rubber grommet back onto the plastic piece. then simply snap back into the door jam. I have ran 14GA speaker wire and 16 gauge alarm wire for door poppers though the loom. Use a hanger going in through the inside of the door to the inside fender with the rubber straightened out and you can feel and bend the hanger as needed.
DeOppressorLiber is offline   Reply With Quote
The Following User Says Thank You to DeOppressorLiber For This Useful Post:
448hpsti (09-15-2013)
Old 09-15-2013, 10:19 PM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
Pull grommet off both sides, take plastic piece off , use a coax cable and run it in first and fish the wires through .. Coat hanger might damage wires
Also spray some invisible glass on whatever you end up using to run wires through .. It lubricates and dries up so no residue
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
kmbkk (09-16-2013)
86 with Lamborghini Doors quik1987 Cosmetic Modification (Interior/Exterior/Lighting) 102 04-10-2018 09:32 PM
Innovate Install Help - Vacuum Routing swift996 Forced Induction 36 07-15-2013 07:47 PM
WTH is this behind both doors?! SlamHoggin69 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 06-24-2013 10:58 PM
wire routing for door speakers derka-derka Electronics | Audio | NAV | Infotainment 6 12-13-2012 09:49 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
