Old 06-25-2014, 07:44 AM   #1
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
18x9.5 et 40- temporary on stock suspension? spacers?
Hey guys I'm picking up a set of 18x9.5 et 40 with 265/35/18 tires. I won't have my kw v3s installed yet, I'm driving to meet someone and trade wheels. I'll need to drive for a day or two with the stock suspension. I know it won't fit without spacers, but how big of spacers will I need to make it work. Like I said this is just temporary, I'll be installing the kw's the next day.
Also will the wheels poke enough on stock suspension that I need to worry about them hitting my fenders on a pothole, or will the stock suspension not travel that far ?
Thanks
mkivalex is offline   Reply With Quote
Old 06-25-2014, 07:50 AM   #2
FR-S Matt
Thanks
I barely fit 18X9.5 +38 on stock suspension, so I'd imagine +40 will rub. When I got my wheels mounted, even Discount Tire was questioning the front in rubbing while it was off the ground. Thankfully, it gained a little clearance when it dropped. Just don't go airborne anytime soon! I'd go with one 3mm spacer in the meantime and that should hold you over.
Old 06-25-2014, 08:36 AM   #3
mkivalex
Appreciate the quick response. 3mm is no big deal at all! Thanks!
V3 spacers on stock setup BRZrkr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-14-2014 01:42 AM
Spacers & rubbing on stock phrosty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-25-2014 07:10 PM
AJ USA Inc. Suspension, Alignment kit, Wheel spacers AJUSA.com Brakes, Suspension, Chassis 16 12-06-2013 01:57 PM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
