Old 04-25-2014, 12:05 PM   #1
phrosty
Spacers & rubbing on stock
I've got stock suspension, and want to grab some 18" wheels. Assuming I find wheels that do not rub even on sharp turns, would adding spacers to make them flush introduce the possibility of rubbing?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 04-25-2014, 12:19 PM   #2
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Seriously doubt it. 18's on stock suspension still gives you plenty of travel. Even if your wheels poked out pass the fender you still shouldn't rub.
If you're looking for some spacers I actually just listed mine for sell this morning. Here's the thread.
http://www.ft86club.com/forums/showthread.php?t=64374
ericmpena is offline   Reply With Quote
Old 04-25-2014, 12:33 PM   #3
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I have eibach prokit running 18x8.75 35offset w 225 40 tires. I can perfectly fit two fingers between my tire and fender, even at that I don't think there's a concern. At stock height u should be fine
Old 04-25-2014, 04:18 PM   #4
phrosty
Not worried too much about the diameter (as that won't change significantly with proper tires) -- it's the width/offset I'm concerned with.
Two issues, if you don't mind helping a wheel newbie out -- I'm nervous about spending $1500 on new wheels only to find I can't make tight turns or something.
First, I see people getting coilovers to make room for a larger width wheel, but I'm fully stock. Would a large enough spacer eliminate the need for coilovers?
Second, if I do put spacers on, it will obviously make the distance the wheels arc while turning larger -- which I see as more potential to rub on the walls of the wheel well when doing a sharp turn. Is there a HOWTO somewhere that explains how I'd combine wheel and tire dimensions to ensure a 100% clearance?
Old 04-25-2014, 05:30 PM   #5
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Damn the fitment of you wheels is great!
How's the prokit + 18s for dd?
Old 04-25-2014, 05:37 PM   #6
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Putting spacers on is effectively the equivalent of going with a more aggressive offset. For example, if you have 20mm spacers and you have wheels of +45mm offset, your effective offset would be +25mm. Then just go to the wheel fitment thread here on the ft86club forums to see how well the +25 mm offset will fit at stock height and with 1" drop. Obviously the real test is still in the fit test.
mit_peid is offline   Reply With Quote
Old 04-25-2014, 07:10 PM   #7
Skurj
Drives: SOLD...
I am using eibach pro kit springs on stock shocks/struts with 18x8.5 ET38 fronts with 225/40/18's and 18x9.5 et 38 255/35/18 and no rubbing and no spacers.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Wheel Spacers on stock wheels?? Husker BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 140 08-01-2020 01:05 PM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
spacers and stock studs abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-17-2013 10:55 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
