Drives: 2013 Scion FR-S Ultramarine
Driveshaft causing intermittent vibrations
Hey guys and gals,
To keep it short, just installed an OFH, Perrin 2.5 res cbe, Dss aluminum driveshaft and JDM underpanels today! Loving the new setup, but I do notice a few occasional short, sharp vibrations through the gas pedal when turning on uneven ground and accelerating. Feels like when ABS engages. I'm not too concerned about it, as the cbe settled cockeyed so I have to adjust the tips; but I'm thinking the driveshaft is moving about a little more (since it's a 1-piece vs the oem 2-piece) and it's probably rubbing on the under panels near the driver footwell. Just thought I'd get your thoughts for anything else it could be before I take a look in there tomorrow. Thanks for the input!
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
#2 | |
aeiou
Drives: WRB BRZ
Both steel and carbon fiber are better at dampening vibrations. Factory driveshaft is steel IIRC.
I noticed this while looking into building my road bicycle. You'd see a lot of aluminum frames to save weight, but they'd have CF forks to dampen vibrations. Then you'd see all steel frames, steel forks as well. Or all CF for those with $$$$$ If anything I would imagine the 1-pc driveshaft moves around less than the 2-pc.
#3 | |
My bad with the word choice, I didn't mean to say the AL shaft is actually moving around more, I mean more like there could be more play between it, the diff and the tranny on a sharp turn. My thinking was the factory one can flex at the joint so it copes a bit better with that sharp turn/accel scenario, where the AL one shifts slightly but just enough to rub one of the underplates. I could be way off though, wont know for sure till I get under there. Sent from my XT1056 using Tapatalk
Drives: 2025 BRZ, ex-2012 GT86
I have a CF one and I think I know what you are talking about. I think it's related to spin of the rear wheels - happens most noticably when you accelerate hard from low speeds especially on wet asphalt and at harsh turns when the car suddenly goes sideways a bit but before the traction control engages. My feeling was that it happens because the DS-differential connection point shakes a lot in stock bushings w/o a differencial brace and it feels much stronger than with the stock DS because of the 1-piece nature of the aftermarket one.
Just a dude
Drives: Scion FR-S 2013
You can turn shaft 180 degrees on diff plate and try that to see if vibes etc are less. With Alu shafts this is common. It's either by luck best on 1st bolt up or spin it 180 and try again see if it's less.
Drives: Toyota 86 GTS
If you have a vibration with a lot of steering input at low speed (like taking off after backing out of your driveway), that's the diff doing its job, nothing to do with your driveshaft.
The Angry Brit
Drives: 1991 E30 318iS
I have a driveshaft shop aliminum DS on my car, and it makes a little noise in first and part of second if I'm cheap with the gas pedal. I'm pretty sure its the syncros being amplified through the aluminum. I have no vibration though? Even at 120 no vibe.
Drives: 31 Ford, Viper GTS,65 Riviera,Cayen
do you have any poly or solid mounts in the car ?
no all the bushings are still OEM
Thanks chaps for the replies so far! going to try turning the shaft (...LADIES...) and some have suggested checking the bolts/clips on the underpannels as well. I live on a somewhat rutted gravel road so I wouldn't be surprised if that loosened something up down there. Sent from my XT1056 using Tapatalk
#10 | |
#11 | |
/thread ![]() Sent from my XT1056 using Tapatalk
| The Following User Says Thank You to Xinshadow For This Useful Post: | Efferalgan (06-24-2014) |
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 05:21 PM |
| FS: Driveshaft Shop (DSS) aluminum driveshaft (for AT only) $350 | dp1 | Transmission and Driveline | 8 | 06-18-2014 04:16 PM |
| New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft | Evasive Motorsports | Engine, Exhaust, Transmission | 1 | 09-24-2013 02:27 PM |
| WTB: Driveshaft Shop (or lighter) driveshaft | Anthony | Want-To-Buy Requests | 8 | 08-27-2013 12:30 PM |
| Driveshaft Shop CF Driveshaft installed. | Hawaiian | Engine, Exhaust, Transmission | 5 | 08-13-2013 02:04 PM |
