Old 06-24-2014, 02:14 AM   #1
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Driveshaft causing intermittent vibrations
Hey guys and gals,
To keep it short, just installed an OFH, Perrin 2.5 res cbe, Dss aluminum driveshaft and JDM underpanels today! Loving the new setup, but I do notice a few occasional short, sharp vibrations through the gas pedal when turning on uneven ground and accelerating. Feels like when ABS engages. I'm not too concerned about it, as the cbe settled cockeyed so I have to adjust the tips; but I'm thinking the driveshaft is moving about a little more (since it's a 1-piece vs the oem 2-piece) and it's probably rubbing on the under panels near the driver footwell. Just thought I'd get your thoughts for anything else it could be before I take a look in there tomorrow. Thanks for the input!
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 06-24-2014, 02:24 AM   #2
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Both steel and carbon fiber are better at dampening vibrations. Factory driveshaft is steel IIRC.
I noticed this while looking into building my road bicycle. You'd see a lot of aluminum frames to save weight, but they'd have CF forks to dampen vibrations. Then you'd see all steel frames, steel forks as well. Or all CF for those with $$$$$
If anything I would imagine the 1-pc driveshaft moves around less than the 2-pc.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 06-24-2014, 02:33 AM   #3
Xinshadow
True story! I don't mind the extra vibrations, since the AL unit is half the price of the CF one and the cf is only about 1lb lighter. Plus I dunno, makes it feel more "racy". I'm weird in that I like my fun cars to be slightly uncomfortable like that.
My bad with the word choice, I didn't mean to say the AL shaft is actually moving around more, I mean more like there could be more play between it, the diff and the tranny on a sharp turn. My thinking was the factory one can flex at the joint so it copes a bit better with that sharp turn/accel scenario, where the AL one shifts slightly but just enough to rub one of the underplates. I could be way off though, wont know for sure till I get under there.
Sent from my XT1056 using Tapatalk
Old 06-24-2014, 04:35 AM   #4
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
I have a CF one and I think I know what you are talking about. I think it's related to spin of the rear wheels - happens most noticably when you accelerate hard from low speeds especially on wet asphalt and at harsh turns when the car suddenly goes sideways a bit but before the traction control engages. My feeling was that it happens because the DS-differential connection point shakes a lot in stock bushings w/o a differencial brace and it feels much stronger than with the stock DS because of the 1-piece nature of the aftermarket one.
Efferalgan is offline   Reply With Quote
Old 06-24-2014, 05:09 AM   #5
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
You can turn shaft 180 degrees on diff plate and try that to see if vibes etc are less. With Alu shafts this is common. It's either by luck best on 1st bolt up or spin it 180 and try again see if it's less.
Old 06-24-2014, 05:58 AM   #6
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If you have a vibration with a lot of steering input at low speed (like taking off after backing out of your driveway), that's the diff doing its job, nothing to do with your driveshaft.
Old 06-24-2014, 06:32 AM   #7
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
I have a driveshaft shop aliminum DS on my car, and it makes a little noise in first and part of second if I'm cheap with the gas pedal. I'm pretty sure its the syncros being amplified through the aluminum. I have no vibration though? Even at 120 no vibe.
VacantSky is offline   Reply With Quote
Old 06-24-2014, 12:21 PM   #8
Driveshaft Shop
Drives: 31 Ford, Viper GTS,65 Riviera,Cayen
do you have any poly or solid mounts in the car ?
Driveshaft Shop is offline   Reply With Quote
Old 06-24-2014, 12:26 PM   #9
Xinshadow
no all the bushings are still OEM
Thanks chaps for the replies so far! going to try turning the shaft (...LADIES...) and some have suggested checking the bolts/clips on the underpannels as well. I live on a somewhat rutted gravel road so I wouldn't be surprised if that loosened something up down there.
Old 06-24-2014, 02:51 PM   #10
Efferalgan
It will give you nothing. Turning the shaft is the solution for vibrations on high DS rotation speeds.
Old 06-24-2014, 05:45 PM   #11
Xinshadow
Took it for a 3 hr drive today, and I think this is right on the money after spending more time with it. Its exactly as you describe, happens durring cornering with either high throttle or sharp turn in, and before the trac light kicks on. All the bolts underneath are good, and I didn't bother turning the driveshaft since I don't experience the higher speed vibrations. At this point I'm happy to say its normal, and I love how much smoother the driveshaft makes gear changes, plus the quicker revs. Great bang for the buck mod!
/thread
The Following User Says Thank You to Xinshadow For This Useful Post:
Efferalgan (06-24-2014)
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 06:21 PM
FS: Driveshaft Shop (DSS) aluminum driveshaft (for AT only) $350 dp1 Transmission and Driveline 8 06-18-2014 05:16 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 03:27 PM
WTB: Driveshaft Shop (or lighter) driveshaft Anthony Want-To-Buy Requests 8 08-27-2013 01:30 PM
Driveshaft Shop CF Driveshaft installed. Hawaiian Engine, Exhaust, Transmission 5 08-13-2013 03:04 PM
