Old 06-23-2014, 03:42 PM   #1
sluflyer06
Drives: 2014 BRZ Ltd - DGM
When do you consider the oil warm
Just curious if anyone has opinions or actual data on what temperature we should be letting the oil get to before we consider the engine ready to drive hard?
On my 135i I always waited until 160F. I'm currently waiting on a bluetooth OBD2 reader to come in so I can check oil temps, kinda feel like I'm flying blind on this car (only had it a couple weeks) without a stock oil temp gauge like I used to have.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 06-23-2014, 04:34 PM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Depends what you mean by "hard", I always wait until my oil is up over 180 before giving it 10/10ths at the track, but I have no scientific data to back up my reasoning. I chose that number because 180 is just before my oil cooler thermostat opens.
Decay107 is offline   Reply With Quote
Old 06-23-2014, 05:13 PM   #3
mike the snake
My old 135i took 10-15 minutes of driving before the oil was up to temp.
Coolant rises to temp within a couple minutes, but oil takes 10 minutes or so on any car.
SO, if you want to be safe, just don't drive hard until you've driven the car for at least 10-15 minutes.
Old 06-23-2014, 06:01 PM   #4
sluflyer06
Yea well I'm all about the common sense route but I'm more of a hard data kinda guy (work in aerospace). My 08' 135i took anywhere from a relatively short amount of time in summer to almost my entire commute to finally even hit 160. Maybe I'll just call it 160 again and read that from Torque on my phone once my obd2 adapter comes in since I'm not wanting to put gauges in this car like I did on my WRX.
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 06-24-2014, 06:47 PM   #5
Dezoris
Dezoris's Avatar
Oil pressures reach normal levels at around 175-180F.
Old 06-25-2014, 10:10 AM   #6
sluflyer06
Thanks. That based on data you've collected on this motor?
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 06-25-2014, 11:34 AM   #7
Dezoris
Dezoris's Avatar
Yes, data logging for over 2 weeks now temps/pressures.
And oil temps for over a year.
Old 06-25-2014, 02:23 PM   #8
sluflyer06
Awesome thanks, I know what temps I'll be looking for now once I can read the values. I figured someone who already had access to the data would have looked into it.
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 06-25-2014, 03:44 PM   #9
Dezoris
Dezoris's Avatar
I think we all get nuts about oils, pressures and temps. Over think it.
However it's common knowledge higher oil pressures mean more wear. At first monitoring oil temps I figured pressures would be stable by 150-160F.
But really oil pressures does not stabilize until temps get to that 175F-180F range, which means pushing the motor at all before that point is just extra UN-needed wear.
For example at 3500RPM when oil is at 150F I generally get 80-85PSI readings. At 180F I see stabilized 50PSI readings and that drops the more heat you get in the oil. But never less pressure than RPMs. (3500RPM 35-40PSI when above 210F)
When we start talking about coolers and over cooling oil you don't want to operate this motor hard below 175F based on what I have seen with pressures.
So if you are in a colder climate and have an oil cooler its something to note.
Old 06-25-2014, 10:45 PM   #10
mike the snake
This makes sense, because, all oils are designed and rated at operating temps, which I believe is 210-220.
Below these temps and oil is thicker, pressures higher, and water/condensation never gets boiled out.
Above these temps and oil is thinner, pressures lower.
From what I've read here that people have logged, unless running on track, oil cooler keeps temps too low.
For example at 3500RPM when oil is at 150F I generally get 70-75PSI readings. At 180F I see stabilized 50PSI readings and that drops the more heat you get in the oil. But never less pressure than RPMs. (3500RPM 35-40PSI when above 210F)
Old 06-26-2014, 09:16 AM   #11
sluflyer06
On street driven cars, oil coolers should never be run without a thermostat. That's my opinion anyway. It is counterproductive to bring the oil temps below ideal range.
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 06-26-2014, 10:54 AM   #12
mike the snake
From what I've seen, even with thermostat, temps are around 180 which is where the thermostat opens. Only until running on track do temps rise to above 200, where they did stay stable on the logs posted.
Since I'm building my car for track use eventually, I plan to install an oil cooler, but I'm going to either tape it up, or undo the lines until it's needed.
Old 06-26-2014, 11:01 AM   #13
sluflyer06
I'd imagine in summer most people would be ok, but people who get real winter and no thermostat would be in trouble.
Even with oil cooler on my previous car oil temps on street were 230-260
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 06-26-2014, 01:35 PM   #14
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I replaced my 180F thermostat with a 203F thermostat. It has helped as my oil is around 195F-200F during normal driving, versus the 175F-185F I saw before.
Having a front license plate is also beneficial to block a little air flow. I saw a 20F drop at the track when I removed it.
BatStig is offline   Reply With Quote
Warm air from vents blunova Issues | Warranty | Recalls / TSB 131 10-06-2020 01:27 PM
Warm Up? gt865 Scion FR-S / Toyota 86 GT86 General Forum 71 09-17-2014 11:28 AM
Do you warm up the car every morning b4 driving? qqzj BRZ First-Gen (2012+) — General Topics 56 04-24-2014 03:18 PM
Ignition for Cat warm up Toyota John Software Tuning 8 04-16-2014 12:14 PM
Warm up time white_knight Scion FR-S / Toyota 86 GT86 General Forum 47 03-14-2013 03:55 PM
