Old 04-14-2014, 09:31 AM   #1
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Ignition for Cat warm up
Anyone change their ignition table, initial start for catalytic warm up. I was thinking about changing the numbers to make it a little less loud on start up. I think I saw -15 in the table. Which makes sense to have fuel still burning in the exhaust to help heat up the catalytic converter. Anyone change this and what numbers are you running?
Toyota John is offline   Reply With Quote
Old 04-14-2014, 10:55 AM   #2
Toyota John
Calle Atun
I was going to try +10 and John V confirmed that's a good number. Anyone try? I plan on doing it tonight.
Old 04-14-2014, 11:45 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
+10 as in 10 degrees advance or -15+10 thus 5 degrees retard? I've been using -6 in mine.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-14-2014, 12:07 PM   #4
Toyota John
Calle Atun
I meant 10 before BTDC. In ecutek it lists them as before is + and after is - i think. I looked at it yesterday quick so I might be wrong. I think is said stock is -15 so 15 ATDC? I put a full exhaust with UL header on Saturday and it is way too loud. I think I need a different cat back system or i might try the tip silencers. Every car my brother has had the silencers in they just vibrate out on the highway and are gone forever.
Old 04-16-2014, 08:38 AM   #5
Toyota John
Calle Atun
Ok so I changed it. Much more quite start up. Then on the second start up I get P050B code something about start up ignition failure. I check that off and reflash and my start up RPM is now 2500. John V said I needed to miss with the MAF scaling to get the RPM down but haven't done that yet. Anyone else try?
Old 04-16-2014, 08:41 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
http://www.ft86club.com/forums/showthread.php?t=55676
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-16-2014, 10:05 AM   #7
Toyota John
Calle Atun
wow great read. Just what I was looking for. I copied the instructions. Hopefully I can find the tables in ECUTEK that look the same as ROMRAIDER. I will try doing during lunch break.
Old 04-16-2014, 11:26 AM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
I use ECUtek mate. As I posted most of the tables to find, you'll find them.
If you search by function:
> Idle Control > Target
> Ignition Timing
Those should be where you find all the tables
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-16-2014, 12:14 PM   #9
Toyota John
Calle Atun
I just meant the MAF correction start up table in ECUTEK. I don't think i have looked at them yet. I have missed with the 9 idle tables before to raise the idle to 750 after it already been warmed up. Do you happen to know the parameters of the 9 idle tables and what each one does? I just made them all the same. Thanks for the help.
Warm air from vents blunova Issues | Warranty | Recalls / TSB 131 10-06-2020 01:27 PM
Warm Up? gt865 Scion FR-S / Toyota 86 GT86 General Forum 71 09-17-2014 11:28 AM
How long do you warm up car before driving? djmm Scion FR-S / Toyota 86 GT86 General Forum 62 04-13-2014 02:34 AM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 12:03 AM
Warm up time white_knight Scion FR-S / Toyota 86 GT86 General Forum 47 03-14-2013 03:55 PM
