Old 02-11-2013, 10:54 PM   #1
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
OK wheel gurus, wheel are here, now for tires
Wheels are Rota Grids 18x8.5 e44 / 18x9.5 e38. I want to run 235 40 18 in the front and 265 35 18 in the rear. Is the do-able with the stock suspension ( for now while I save my pennies for springs or coilovers ). And then will it work with a drop of 1 inch to 1.5 inches?
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 02-12-2013, 12:28 AM   #2
Fortunate Few
will photoshop for ft86
Fortunate Few's Avatar
Drives: 07 Mazda RX8
Send a message via AIM to Fortunate Few
you're probably gonna wanna go skinner on the rears like 255 or 245. 265s might work at stock height but when you lower you're probably gonna rub depending how low you go and what camber you wanna run.
Fortunate Few is offline   Reply With Quote
Old 02-12-2013, 12:59 AM   #3
Stance86
Drives: Toyota 86 GTS
265's are going to be pushing it but I can assure you 235/40 and 255/35 will fit (thats what I am running on lowering springs only)
Stance86 is offline   Reply With Quote
Old 02-12-2013, 01:23 AM   #4
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
265 might rub only because your offset is too low. Might want something like a +45 if you want to run anything higher than 38, or you can run a few degrees of camber
Tansey86 is offline   Reply With Quote
Old 02-12-2013, 01:28 AM   #5
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
235/40 is just right stretch for a 9.5?
tintumz22 is offline   Reply With Quote
Old 02-12-2013, 01:36 AM   #6
Tansey86
Tansey86's Avatar
235 should not go on a 9.5
Insight on winter wheel/tires? BRZranger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 61 09-20-2013 11:06 PM
FS: New OEM Wheel/Tires/TPMS (2 Available) kanundrum Wheels and Tires 1 02-07-2013 11:59 PM
Need help from the wheel fitment gurus nab335 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 10-11-2012 01:39 AM
Wheel Choices for OEM Tires Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 09-29-2012 01:10 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
