Drives: None
How much would a dealership charge to replace all four injectors?
I keep hearing a popping noise every time I start her up... I went FI while my car had 23k miles on it, now I have 25k and I hear this popping sensation in my car.. I'm pretty sure it's the direct injections. How much would a dealership charge to fix it?
Sent from my iPad using Tapatalk |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
As each dealership probably would quote you a different price, there's no way to tell without calling.
That said, what makes you think it's the injectors? And (if they are defective) what makes you think replacing them will fix the issue that caused them to go bad in the first place? I'm going to ballpark $2-5k for engine repairs through the dealer to fix your problem - unless they won't even touch a modified engine bc they can't warranty their work, in which case they would probably say return it to stock, and then they can look in to it, or suggest you buy a whole new engine. From your post it's impossible to say really, but I'd go through the shop that installed your FI system (supercharger or turbo?) and see what they say. Though if they messed up the job, they might not be the best shop to have working on your car. Good luck. Edit: my other car has an aftermarket supercharger added, though it was arranged through the dealer but sent to Dinan for installation, it's still aftermarket. Whenever I have work done it costs extra bc they have to remove the supercharger to get to the valve covers, etc. And then of course they have to re-install it when they're done. No fun. Ok, the supercharged V8 is fun, the maintenance costs - not so much fun. |
#3 | |
Drives: Celica 5th Gen, Tiburon 04, GT86
Why would the injector make a popping noise? Also, can't you try to pinpoint which one it is using the GTS Active Test stuff? |
Small penis big dreams
Drives: '13 Scion FR-S
the local shop charged me 1 hour of shop time to replace my aftermarket injectors
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE 277hp 93 octane 370hp on E-85 |
Drives: 2014 BRZ Ltd - DGM
You're referrring to your standard fuel injectors, OP is referring to the Direct Injection injectors which would be in the head.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
reading trumphs all
Heh its ok, if only the direct injectors or spark plugs were that easy to get to.
2014 BRZ Ltd. - DGM
Drives: None
i miss read what you wrote but you were talking about the direct injectors and i was talking abou the fuel injectors. anyways it was 90.
#10 |
Drives: Asphalt FR-S
[ame="https://www.youtube.com/watch?v=sdeO4rBwuQ4"]Scion FR-S BRZ Direct Injector Seal Replacement | Problems and Issues - YouTube[/ame]
Could be useful if you wanna DIY
#11 | |
Drives: FR-S 6MT
not uncommon to hear a pop or feel a "miss" when cold, but should not occur after warmup. |
#12 | |
Drives: None
Sent from my LG-D800 using Tapatalk |
#13 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Don't count on it being injectors. Lots of things make pop sounds in the exhuast
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
#14 |
in orbe terrum non visi
Drives: violent
Sounds like di seals.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| Does the USB port charge your phone? | EAGLE5 | Electronics | Audio | NAV | Infotainment | 30 | 08-15-2014 01:44 AM |
| Labor time to replace pump and injectors? | misooscar | Forced Induction | 4 | 06-10-2014 10:37 AM |
| Do you feel in Charge? | LS13 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 03-28-2014 09:01 PM |
| Dealership is charging me $1725 to replace my OEM clutch for BR-Z | venom8776 | BRZ First-Gen (2012+) — General Topics | 147 | 02-02-2014 08:34 AM |
| ECU Charge??? | DBacon1052 | Issues | Warranty | Recalls / TSB | 12 | 09-18-2012 11:53 PM |
