Old 06-09-2014, 06:55 PM   #1
misooscar
misooscar's Avatar
Drives:
Labor time to replace pump and injectors?
I did a search, but I did not find this topic discussed before...
If you've had a shop swap out your injectors and fuel pump, how much did it cost for labor?
Thank you in advance.
misooscar is offline   Reply With Quote
Old 06-09-2014, 07:38 PM   #2
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Pumps are usually an hour billable, injectors are 2 - 3 on an EJ / FA.
Regards!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
misooscar (06-09-2014)
Old 06-09-2014, 08:21 PM   #3
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I did my pump in about 30 minutes and shop charged me an hour labor for injectors
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
Old 06-10-2014, 09:39 AM   #4
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
IMHO injectors are quicker than the pump if you have the disconnect tool. It took me about an hour in my driveway to change the injectors but I did have PnP harnesses.
The pump is a pain not only to remove but then you have to hack up the canister to fit the new pump and fuel sock. Then you need to figure out the o-ring and factory sock song and dance. Put everything back together and not kink any of the hoses.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
misooscar (06-12-2014)
Old 06-10-2014, 10:37 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would say pump takes longer than injectors. Most shops are going to charge based on book times regardless of how long it takes though. I would say budget for 3 hours x whatever your shop's labor rate is which can vary from $50 an hour to over $150 an hour.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Drift-Office (06-10-2014), misooscar (06-12-2014)
New injectors and pump, idle dip when tipping in the throttle? HRTROB Forced Induction 22 05-12-2014 01:31 PM
FS: OEM Radiator, Injectors, Fuel Pump, Airbox, and Wheels. Sterz Engine, Exhaust, Bolt-Ons 12 03-19-2014 11:56 PM
Should I let Toyota replace my fuel pump? Hakuzen Issues | Warranty | Recalls / TSB 51 12-29-2013 06:50 PM
Vortech Supercharged 270whp 86 AT stock injectors and pump Tye300 Forced Induction 3 12-16-2013 06:52 PM
Asking for $275 OBO... FS: Bosch 500cc Injectors, SBD 290 LPH Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 116 09-18-2013 10:19 AM
