Old 02-06-2013, 10:38 PM   #1
pkny
Drives: Firestorm FR-S 6MT
Scangauge xgauge code for oil temp, seat belt beep disable, and more
Working code for FR-S/BRZ/86:
Code:
Gauge                          Unit           TXD                  RXF                      RXD      MTH                      Note
Oil temp                       C         07E02101       010702E80324     3008    00010001FFD8    Required FW 4.05 or higher
Oil temp                       F         07E02101       010702E80324     3008    00090005FFD8    Required FW 4.05 or higher
Precise Fuel Level         %         07C02129       046105290000     2808    000100010000    Faster refresh rate
Precise Fuel Level    US Gallons   07C02129       046145290000     2808    052900640000    Faster refresh rate
Precise Fuel Level       Liters      07C02129        046145290000     2808    01F4000A0000    Faster refresh rate
Seat Belt Beep Query               07C021A7        046115A70000     2808    000100010000   C0 for stock, 00 for disable
Seat Belt Beep Disable              07C03BA700    047B15A70000     2008    000100010000   Should return 0000. Replace '00' in the TXD with 'C0' to go back to stock.
Relative Throttle Position      %           07E00145            044185450000         2808     03E800FF0000
Absolute Throttle Position     %           07E00147            044185470000         2808     03E800FF0000
Fuel Pressure                     PSI         07E00123            046105230000         2810     006400450000
Fuel Pressure                    MPa         07E00123            046145230000         2810     000100010000
86 Standard PIDs.doc is the list of supported standard (mode 01) PID for 86/BRZ/FR-S. This list is created from the Wiki’PID, and I highlighted the ones that are supported by our cars.
Here is an example of how to make use of the doc I created:
From the Xgauge cansf list, the short Term Fuel Trim Bank 1 has the TXD 07E00106. The 01 (07E00106) is the mode #. The 06 (07E00106) is the PID. Now look at the doc I attached. It shows the PID 06 is supported, which means that xgauge code works on our cars. The PID 07, On the other hand, is not highlighted on the list. That means the Short Term Fuel Trim Bank 2 is not supported.
Thank you Andery for finding the PID and torque’s code for oil temperature. Without him, I don’t think I can get the oil temp for xgauge.
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
Old 02-06-2013, 10:49 PM   #2
jonnyboy
Drives: GTS 86 6AT
You are amazing!
Thanks for figuring this out!
jonnyboy is offline   Reply With Quote
Old 02-07-2013, 02:26 AM   #3
jonnyboy
Drives: GTS 86 6AT
Not sure if my the codes would vary by locality, but on my scangauge I had to alter one value in the MTH:
MTH 00010001FFD8
Old 02-07-2013, 02:45 AM   #4
pkny
Jonnyboy, thank you for catching my typo. Yeah, it should be 00010001FFD8. It has been a long day. Anyway, the 1st post was corrected.
Old 02-07-2013, 05:03 AM   #5
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
worked for me... a million thanks!
86•BRZ is offline   Reply With Quote
Old 02-07-2013, 06:22 AM   #6
Nardi330
Nardi330's Avatar
Drives: 86
Sorry for bring a noob. Can you also post the steps to setup in the scangauge?
Thanks in advance.
Edit: never mind, found some instruction online and Weill try it later.
Nardi330 is offline   Reply With Quote
Old 02-07-2013, 10:34 PM   #7
Synack
Boosted
Synack's Avatar
Drives: Sideways
The IA is intake air temp?
What's WT, water?
Old 02-07-2013, 10:43 PM   #8
R2
I've had my eye on the ScanGuage for quite awhile, this is great. By the way, will the Scanguage fit in the slot under the a/c controls? It looks close, maybe not for the push button start equipped cars but perhaps the ones without.
R2 is offline   Reply With Quote
Old 02-07-2013, 10:51 PM   #9
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
http://www.scangauge.com/image-resou..._with-dims.jpg
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 02-07-2013, 11:07 PM   #10
R2
Originally Posted by mr_m View Post
Boom. There it is, thanks.
Old 02-07-2013, 11:09 PM   #11
TIE Pilot
TIE Pilot's Avatar
You can set the The ScanGaugeE the same right? Since is more than an 1" shorter should fit b/w start button and usb
Old 02-07-2013, 11:24 PM   #12
R2
So I couldn't find my tape measure but with a shitty ruler I found that there is plenty of width for the standard unit. However, height is an issue and you may have to remove or trim the rubber in the slot. The height of the slot without that rubber is over 1.5" though so it can work. My other concern is the display contrast - can you see the display clearly from the drivers position if it were installed there flush with the dash?
Old 02-08-2013, 02:03 AM   #13
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
What's WT, water?
yep, exactly right
Old 02-08-2013, 02:07 AM   #14
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
here is a pic I found on these forums somewhere
Ill have to look into the scangauge E, hopefully it will fit in the start button models. I pinched this scangage from my other car anyway..
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
exterior temp. gauge off? Rayme CANADA 8 01-23-2013 09:06 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
