Drives: Celica 5th Gen, Tiburon 04, GT86
MiniVCI and Global Techstream
Anyone messing around with GlobalTechStream and the MiniVCI cable? I've got it all setup and done a few GenericOBDII scans on my older car (Nissan), but haven't had the guts yet to plug it into my brand new under garantee GT86... I've heard the dealer can detect it's been plugged up and break the warranty. Anyone know anything about this?
#2 | |
Drives: FR-S 6MT
Used the diagnostics. The dealer can't detect you using it unless you modify and save ECM code. There are several options on the car you can modify. A very useful tool. |
Drives: 2013 asphalt scion FRS
I have it. Changed my DRL setting, lock/unlock settings, all the annoying alarm settings. It's the same software THEY use. So...I highly doubt they could void your warranty.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
Thanks guys, well I guess I just have to plug it in now and check for myself... I'd like to turn the daylight leds off, I've seen there's an option for this in the repair manual
Yes, the DRLs can be turned off.
Village Idiot
Drives: '13 FR-S Ultramarine Manual
Does anyone have access to one here in socal? I would love to be able to turn those off.
#7 | |
Drives: FR-S 6MT
Dealer here and they wanted 75 dollars to change the options. So I bought the cable for $30 and DL the software here for free.. Installed on my win7 laptop and made the changes. It also has diagnostic functions and allows you to monitor the system temperatures and other operating specs. Very useful tool. |
#8 | |
Drives: 2014 FR-S 6MT Whiteout
Which cable do you guys recommend?
#10 |
Here's the one I've got.... nice thing is that it comes with the drivers and the GTS software, so you're all set to go:
http://www.ebay.com/itm/201078107255...R:3160&vxp=mtr |
#11 |
I got mine from amazon. Actually came with drivers and the techstream copy for 30 bucks. But...I won't recommend it to anyone, for the simple fact the drivers are for XP. And it was a PITA to work around it to install on W7
#12 | |
Drives: Toyota 86
But you can do so manually by pulling out the DRL relay in the fuse box under the hood. DRL will no longer function, but the LED strip will still light up when you have your parking lights or headlights on. Just pop the relay back in if you want it to work again. |
#13 |
Drives: Asphalt Scion Frs 6MT
If only you could turn off the tpms.
#14 |
TPMS is an interisting one.... it seems to be a standard in USA FRS and not available at all in GT86 europe, whereas for most other things the european version seems to have more standard equipment (electric fold mirrors, auto headlights, dual A/C, plastic underpanels, trunc trim, .... but is much higher priced, but therefore less noobs with them, so I don't think we'll get the Honda Civic symptom you're on about in the US)
| TechStream TIS - No work | FRSFirestorm | Engine, Exhaust, Transmission | 19 | 07-10-2014 03:14 AM |
| Techstream/ECU customizations | phanguy | Northern California | 60 | 10-05-2013 11:12 PM |
| techstream | spitfire481 | Mid-Atlantic | 0 | 09-14-2013 09:37 PM |
| Toyota Techstream on BRZ? | pinoy_dorifto | Engine, Exhaust, Transmission | 6 | 05-15-2013 11:56 AM |
| Techstream ECU Options | mrjester | Electronics | Audio | NAV | Infotainment | 10 | 03-18-2013 10:24 AM |
