Old 05-15-2013, 02:51 AM   #1
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Toyota Techstream on BRZ?
Has anyone tried to use the Toyota Techstream on a BRZ? I mean not on Generic OBD II, but in full use of the software?
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 05-15-2013, 07:33 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
Yes. Everything that worked on the FRS worked on the BRZ, although I didn't mess with the DRL settings at all.
Old 05-15-2013, 07:44 AM   #3
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
What he said. Techstream automatically recognizes the car as an FRS. There are some ECU versions that will not like DRL's being turned off (I think it kills the high beams). So far, other than looking at different engine parameters, I've only turned off the seatbelt chime for the drivers seat (for the times I wear a harness while autocrossing).
celica73 is offline   Reply With Quote
Old 05-15-2013, 08:03 AM   #4
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
I didn't have the option to do any of the chimes, passenger seat weight warning, etc when I played with mine last night. Did I miss a step to allow me to access those features you guys know about?
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 05-15-2013, 08:38 AM   #5
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I'm not familiar with it, but are you able to turn on airbags using techstream if you are using aftermarket seats?
LeeMaster is offline   Reply With Quote
Old 05-15-2013, 08:57 AM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
Usually you have to put a resistor in the stock seat harness so that the car thinks those airbags are operational. Haven't seen the details for doing it in this car though.
Old 05-15-2013, 11:56 AM   #7
pinoy_dorifto
Tuloy po kayo!
Wow, working at a Toyota dealer, I thought Having the Techstream would be one advantage of owning an FR-S, I guess not. Mechanical parts would also be the same, so the only thing that would push me away from the BRZ Limited is the outrageous mark-ups that I hope would be gone when it's time to buy on december.
I.G. @mytoy86
Toyota TechStream Ver GTS_10.10.018 - Diagnostic Tools for FR-S/GT86/BRZ Trap63 Scion FR-S / Toyota 86 GT86 General Forum 225 03-09-2024 03:53 AM
Toyota Techstream xjohnx Engine, Exhaust, Transmission 206 08-20-2023 04:01 PM
TechStream TIS - No work FRSFirestorm Engine, Exhaust, Transmission 19 07-10-2014 03:14 AM
Techstream ECU Options mrjester Electronics | Audio | NAV | Infotainment 10 03-18-2013 10:24 AM
