Old 05-22-2014, 10:59 PM   #1
ang31ito
ang31ito's Avatar
Drives: Scion FRS 2013 - Whiteout
Alignment after 1 inch drop?
So, I had the awesome people at Revworks Orlando install my BC extreme low coilovers, stance camber arms and spacers (20mm front, 24mm rear). They did a great job. After riding for a few weeks, I'm getting a little picky. I want my rear lowered about another inch. I'm planning on doing the adjustment myself. Will I need an alignment after only an inch drop? What if I only drop a half inch instead? Online I'm seeing a lot of advice saying you do need one and also a lot saying you don't. Any suggestions? Here's some pics of where I'm sitting now...
Size:  43.9 KBName:  uploadfromtaptalk1400813868520.jpg
Size:  51.2 KBName:  uploadfromtaptalk1400813883734.jpg
ang31ito is offline   Reply With Quote
Old 05-22-2014, 11:04 PM   #2
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
If you go down another inch, your tire will make love to the fender liner. ALL NIGHT LONG
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
The Following 4 Users Say Thank You to Deadspool For This Useful Post:
jebuwh (05-22-2014), Lonewolf (05-23-2014), Mad1723 (05-23-2014), was385 (05-23-2014)
Old 05-22-2014, 11:05 PM   #3
ang31ito
ang31ito's Avatar
Lmao maybe not an inch but at least a little more. I've seen other frs and BRZ with stock wheels and lower rears. I'm jealous I guess.
Old 05-22-2014, 11:24 PM   #4
ang31ito
ang31ito's Avatar
Originally Posted by ang31ito View Post
Lmao maybe not an inch but at least a little more. I've seen other frs and BRZ with stock wheels and lower rears. I'm jealous I guess. Can it be done?
Old 05-22-2014, 11:38 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
If you change anything suspension wise(other than swaybars) you should do an alignment.
It might not be too far off if you only lower an inch, but you sacrifice tire life...why spend all that money on coilovers and adjustable arms just to not have a perfect alignment?
The Following User Says Thank You to continuecrushing For This Useful Post:
zdr93523 (05-23-2014)
Old 05-22-2014, 11:50 PM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Why do you want to go lower???
The Following 2 Users Say Thank You to boredom.is.me For This Useful Post:
Thrustin (06-12-2014), zdr93523 (05-23-2014)
Old 05-23-2014, 01:43 AM   #7
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Why are your mirrors miss matched? I'd fix that first.
Old 05-23-2014, 02:15 AM   #8
Drifty86
Drifty86's Avatar
Drives: 86 6MT
Attachment 79598
Attachment 79599Attachment 79600Attachment 79601
Dude that's low enough. If you go any lower your car will look retarded. I know is your and all but you will embarrass 86 owners.
Drifty86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Drifty86 For This Useful Post:
B-R-Z (05-23-2014), SportInjected (05-23-2014), TwoChicksOneSTI (02-28-2017)
Old 05-23-2014, 07:30 AM   #9
alan.chalkley
Drives: 4wd zooks
Does the front lip not scrape on driveways?
Mine is stock height and it still scrapes , even with 40psi in the tyres.
alan.chalkley is offline   Reply With Quote
Old 05-23-2014, 08:09 AM   #10
Mad1723
Mad1723's Avatar
Get bigger wheels, it'll fill the gap and you won't have to scrape your fender lining to go any lower.
Stock wheels make it look worse. Get some 18s and your gap will magically disappear!
Mad1723 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mad1723 For This Useful Post:
ang31ito (05-23-2014), TwoChicksOneSTI (02-28-2017)
Old 05-23-2014, 08:41 AM   #11
ang31ito
ang31ito's Avatar
I'll tell you when I'm low enough. I've never even heard such a phrase before, "it's low enough". LMAO. I don't even know what that means. Thanks for your input.
The Following User Says Thank You to ang31ito For This Useful Post:
kalamitykode (05-24-2014)
Old 05-23-2014, 08:41 AM   #12
ang31ito
ang31ito's Avatar
Mismatch is on purpose. Idk if you understood that.
Old 05-23-2014, 08:43 AM   #13
Malt
Drives: 2015 WRX
How does the fact that he wants to lower his car more serve as a means to embarrass 86 owners? I didn't realize that one persons car could be used as a means to identify and shame every single owner of this particular make and model. If he wants his car to look "retarded" then that's his choice.
OP: Yes, if you lower the rear suspension your camber and toe will be out of alignment. You'll need an alignment to fix that to avoid potential issues with handling and tire wear.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Old 05-23-2014, 09:52 AM   #14
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Lower is not better. When you go low beyond the functional benefits of the suspension setup it's pointless, unless it's strictly a show car. Slamming a DD seems dumb to me, why kill your ride quality and front bumper just for the sake of thinking you're impressing someone.
The Following 2 Users Say Thank You to B-R-Z For This Useful Post:
Drifty86 (05-24-2014), TwoChicksOneSTI (02-28-2017)
‡‡‡‡‡ Eibach SportLine Springs - IN STOCK - 1.4 inch drop! Plus package deals! ‡‡‡‡‡ FT-86 SpeedFactory Brakes, Suspension, Chassis 174 12-17-2014 01:41 AM
Alignment required for different size wheels after drop? Shad0ez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-08-2013 03:30 PM
Half Inch Drop? Ray_32 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-28-2013 05:44 PM
Picture of a FRS/BRZ with 18 inch+ wheels, no drop forzajuve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-18-2013 05:22 PM
Can i drop my car an inch or more and then raise it back to stock height? ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-01-2012 09:02 PM
