Old 10-29-2012, 08:46 PM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Arrow Can i drop my car an inch or more and then raise it back to stock height?
i know this may be a dumb question but if i run coilovers or springs just to lower the car an inch to an inch and a half while running 18x8.5 front and 18x9.5 rear with a 35mm front offset and a 40mm rear, 235/40-18 front and 255/40-18 rear will it rub ? and also my main question is can i bring it back up to stock height when i need to for the winter/snow time for clearance issues? can i do this? will it rub ? and also what is the best coilovers to do so ?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 10-29-2012, 08:53 PM   #2
CBR600RR
Drives: Raven Black
Yes you can.
I suggest getting 16" winter wheels and tires to match though
Old 10-29-2012, 08:54 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You'll need an alignment twice a year also.
Rayme is offline   Reply With Quote
Old 10-29-2012, 08:55 PM   #4
CBR600RR
Drives: Raven Black
^ yup
Old 10-29-2012, 08:55 PM   #5
mswhong
I would recommend kw v3's or if you're on a budget, I'd suggest BC coils
mswhong is offline   Reply With Quote
Old 10-30-2012, 09:28 AM   #6
ScionFR-S
ScionFR-S's Avatar
thanks guys !
Old 11-01-2012, 09:02 PM   #7
ScionFR-S
ScionFR-S's Avatar
bump
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 12:57 PM
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop AGM6789 AUSTRALIA 17 11-10-2012 05:10 AM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
K&N Drop-In Filter for BRZ/FR-S in stock! Mach V Dan Engine, Exhaust, Bolt-Ons 0 06-27-2012 02:41 PM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
