Old 11-08-2013, 01:08 PM   #1
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
Alignment required for different size wheels after drop?
So I have my wheels and springs/control arm/camber bolts ordered and it looks like the suspension setup will come before my wheels do. I was planning on an alignment two days after the springs are installed to give them time to settle. Will I need to get another alignment done after I put the new wheels on? The wheels coming in are 18x8 and 18x9 tires 225/40 and 245/40 respectively.
Shad0ez is offline   Reply With Quote
Old 11-08-2013, 01:57 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Wheels shouldn't change your alignment at all. The drop in height will though.
However, depending On the specs of the new wheels, you might want to run a slightly different alignment than before for fitment reasons. Not saying that it's a requirement, but you might want to based on how it looks. Just something to keep in mind.
I'd do the alignment after everything is put on and put it on at the same time. Do it once and be done with it.
TylerLieberman is offline   Reply With Quote
Old 11-08-2013, 03:30 PM   #3
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
let your coils settle in after 200 miles. your tires are not gonna wear out in 200 miles. Then get ur car aligned.
hanabie is offline   Reply With Quote
Oddities: new alignment, tires and wheels rainmonkey Tracking / Autocross / HPDE / Drifting 12 10-25-2013 08:29 PM
Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. Shiro86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-14-2013 09:44 AM
Wider wheels: need an alignment? OakmanSmalls Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 07-18-2013 10:34 AM
Size & spec of TRD wheels? mit_peid Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-09-2013 01:26 PM
What size wheels do you plan on running? poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 04-28-2012 05:30 PM
