Old 05-22-2014, 01:09 PM   #1
puma
crew chief
puma's Avatar
Drives: Race car FR-S
steering sensor
Anyone knows what happens when the steering sensor is unplugged, faulty or missing?
Is it only the abs and vsc that will be affected or will the power steering be affected too?
puma is offline   Reply With Quote
Old 05-22-2014, 02:43 PM   #2
Mister
Mister's Avatar
Drives: Firestorm FRS
I'm going to guess not good things. The car is drive by wire, is it not?
In what case would you want to unplug the sensor?
Mister is offline   Reply With Quote
Old 05-22-2014, 03:10 PM   #3
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Do you mean the angle sensor AKA the clock spring?
If yes the ABS and tracktion control and VSC programs will not function and you will get them all and a CEL on the dash.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 05-22-2014, 03:25 PM   #4
strat61caster
strat61caster's Avatar
It has electric assist, not quite drive by wire, which I assume you mean steer by wire since drive is ambiguous (gas? brakes? clutch?).
Basically in the Toyobaru an electric motor is attached to the steering shaft that helps you turn the wheel, similar to hydraulic power steering systems if it fails you can still turn the wheels it just takes a lot more effort to do so.
I know Nissan is the leader in steer by wire systems but just found out they have it on the streets already:
http://gizmodo.com/what-its-like-to-...ire-1501915995
The failsafe is a clutch that decouples the steering wheel from the actual input shaft, if there is a failure in the system the clutch engages the two shafts together and you have 'standard' steering again.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
ermax (03-07-2019), Mister (05-22-2014)
Old 05-22-2014, 03:31 PM   #5
Mister
Mister's Avatar
Thanks @strat61caster, you learn something new everyday! Thanks for the good read.
And yes I was talking about steer by wire.
Old 05-22-2014, 07:49 PM   #6
puma
crew chief
puma's Avatar
the thing is we are building a race car and it seems like the clock spring where the steering angle sensor is, doesn't work. I want to know if like Khorne said, all the things that won't work are vsc, abs and traction control (which we all disable anyway) and i don't mind about the cel.
So the electric steering assist should still work? I can't try it as the car is in pieces now but i want to know what i need to put back or not.
Anyone knows if the clock spring need to be changed when an air bag deploys?
Old 03-07-2019, 11:34 AM   #7
ok_brz
Enthusiast/Drifter
ok_brz's Avatar
Drives: 2015 Subaru BRZ
Would like to update this thread:
The removal of clock spring DOES NOT take away power steering.
Looks like only things effected are ABS & VSC
ok_brz is offline   Reply With Quote
Old 03-07-2019, 12:01 PM   #8
ermax
ermax's Avatar
Interesting, I was curious how Nissin handled that.
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
install cruise control coz for me roll connector / steering sensor fail aagun Issues | Warranty | Recalls / TSB 15 11-14-2013 09:29 AM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
