Old 10-31-2013, 11:44 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Steering Feel Question Concerning Tic Solid Steering Bushings
So my car has the stock suspension and tires other than the TIC solid alumimum steering rack bushings and the whiteline rear subframe mounts.
The car's steering is certainly direct without sloop but its a little darty and quick to react at high speeds and sensative to road bumps and steet conditions.
I recently hit something driving the required me to replace a front wheel which was bent (no other damage done, even my tire survived). I got a new front alignment and make sure everything was in spec and undamaged.
I'd like the steering feel to be a tad heavier as well as a little less darty. Can I adjustment my alignment to accomplish this? Would urethane rack mounts be better than the solid ones?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 10-31-2013, 11:45 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
buy a Lincoln
or go crazy on castor
Old 10-31-2013, 01:42 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I just installed Energy Suspension poly steering rack bushings, and they are pretty much solid. The PU, is just a thin layer around a solid metal sleeve. I don't poly would change anything.
Old 10-31-2013, 02:12 PM   #4
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I think you need to give slower more controlled inputs, or get wider tires to make it less darty.
As they say in electronics, a system is only as good as the controller.
JDKane527 is offline   Reply With Quote
Old 10-31-2013, 02:26 PM   #5
boredom.is.me
Custom User Title
You probably also bought the wrong car.
Old 10-31-2013, 02:38 PM   #6
brillo
Not unhappy, just trying to dial things in a bit. I'm getting new tires soon which I hope will help some.
Old 10-31-2013, 02:42 PM   #7
OrbitalEllipses
Drives: Attitude
Big ass rear sway bar will help with the darty feeling.
Old 10-31-2013, 02:54 PM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if you want to dial things in, go spend 40 bucks on an indor go-kart session and bomb around the track for one race.
then when you get back in your car you'll feel as if you're driving a boat
problem solved.
happy driving.
The Following 3 Users Say Thank You to 7thgear For This Useful Post:
Calum (10-31-2013), JDKane527 (10-31-2013), OrbitalEllipses (10-31-2013)
Old 10-31-2013, 03:32 PM   #9
Racecomp Engineering
problem solved.
happy driving.
Or drive my 1968 Datsun roadster...it will make your car feel like an F1 car afterwards.
(everyone loves the F1 comparisons these days. i was going to say spaceship)
Really though, better tires might solve your problem.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
CSG David (10-31-2013)
Old 10-31-2013, 03:52 PM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
- Andy
he wants LESS response... his car has too much!
Old 10-31-2013, 04:00 PM   #11
Ah yes, in that case don't drive my Datsun! Do a couple sessions in a kart.
More caster will help.
- Andy
Old 10-31-2013, 04:13 PM   #12
CSG David
CSG David's Avatar
Check tire pressure since it's the cheapest mod. Dial half a psi less in the rear. This should settle the car a bit. Steering assisted by an electric motor. Adding caster will improve the feel slightly.
Old 10-31-2013, 04:16 PM   #13
^ That too. Tire pressures can make a big difference.
- Andy
Old 10-31-2013, 04:41 PM   #14
mike the snake
Wouldn't a little toe-in both front and rear help with this? It'll definitely make the car less darty.
DIY: Turn In Concepts Solid Aluminum Steering Rack Bushing Install (and review) Sithspawn DIY (Do-It-Yourself) Guides 38 08-10-2018 11:07 AM
Turn in Concepts (TiC) solid aluminum steering rack bushings review CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 08-14-2017 08:24 PM
Installed steering, transmission an sub frame bushings, NVH question brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-23-2013 07:13 PM
TIC Solid Steering Rack Bushing's Track Review track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-17-2013 01:24 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
