Drives: Toyota GT 86
Question on pulleys
I'm considering buying a set of pulleys for my car (weekend car use, trackday/autocross every couple of months).
There are sets of 1, 2 (Perrin), 3 (Buddy club, raceseng) or 5 pulleys (raceseng). How much extra benefits do I get from each of them? Every seller out there has info on the benefits of the lighter pulleys, but what I want to know is the downside of changing the pulleys. Today I found out: http://www.ft86club.com/forums/showt...ghlight=pulley "This pulley kit is designed and intended for motorsport applications. Running the air conditioner and headlights at idle can cause an insuffieient battery charge." Anything else I should think about and consider before buying? |
Drives: 13 Scion FR-S
Because compromise ®
Drives: Red Herring
This subject has already been done to death.
I will summarize it for you: 1/ OMG!! This mod has released at least 40 megaWatts and now I can beat Veyrons from the lights. 2/ This mod is a waste of money and you would be better off going on a diet. A search on these forums of "light weight pulley" would have given you these results in addition to the link above. This is not the full list. http://www.ft86club.com/forums/showthread.php?t=61709 http://www.ft86club.com/forums/showthread.php?t=56931 http://www.ft86club.com/forums/showthread.php?t=47079 http://www.ft86club.com/forums/showthread.php?t=13259 http://www.ft86club.com/forums/showthread.php?t=43556 http://www.ft86club.com/forums/showthread.php?t=12450
#4 | |
Drives: 2013 GBS BRZ Limited
![]() ![]() That is funny. I was just commenting the other day at the vintage car races. People spend thousands of dollars to shed a couple of pounds from their car, then you see a 280 lb man squeezing into a spitfire. |
I did a search for pulley. and saw hundreds of posts. nothing had a title that was easy to clue me in on the topic.
thanks guys |
Drives: Red Herring
Drives: 86 GTS Aero
it can also bling up your engine bay! :P
Drives: 2014 Pearl White BRZ
Not worth it. If you go with induction or some other real performance improvement it isn't going to care about those pulleys. Also, there is a reason some things have mass. There is a reason a tuba sounds like a tuba and a piccolo sounds like a piccolo too. Just my two cents. Some folks love them.
| FS: GFB style lightweight pulleys. | dj petey | Canada Classifieds | 8 | 05-08-2014 10:40 PM |
| When would you consider modding pulleys? | 1Cor10:23 | Engine, Exhaust, Transmission | 63 | 03-06-2014 04:04 AM |
| Aftermarket Pulleys | Hotstuf1818 | Engine, Exhaust, Transmission | 3 | 02-08-2014 07:14 PM |
| Ti Racing pulleys | diss7 | Engine, Exhaust, Transmission | 0 | 12-17-2013 04:15 PM |
| Innovate 70 and 72.5mm pulleys are available now! | Xero-Limit | Forced Induction | 4 | 10-19-2013 02:02 PM |
