Old 05-19-2014, 02:28 PM   #1
BRZ_Kamil
Drives: Satin pearl white brz
Guys i dont know if its clear coat chip or paint chip.. HELP
HELP ME! I bought clear coat and paint from subaru but idk which one got chipped.. or both. what should i do?
BRZ_Kamil is offline   Reply With Quote
Old 05-19-2014, 02:37 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Picture would probably be a good idea so we can see what you're concerned about. Normally, if you see primer or bare metal, then you'll have to do the base color and then clear. If you see base color then it's just the clear coat. Unfortunately, the white color requires a base and clear/pearl top so it makes it harder to fix.
cnk is offline   Reply With Quote
Old 05-19-2014, 02:42 PM   #3
BRZ_Kamil
Name:  0518141530 (1)asdf.jpg
Size:  46.9 KB okay this is it
Old 05-19-2014, 02:42 PM   #4
BRZ_Kamil
@cnk
Old 05-19-2014, 02:43 PM   #5
BRZ_Kamil
little dirty probably will wash her today
i have the base white.. and a original clear like not the clear pearl top :/
Old 05-19-2014, 03:24 PM   #6
cnk
The color disparity looks like primer to me. Maybe some others can chime in on this as well. If it were me, I would wash the area, put a couple thin coats of base color, then clear on top.
Old 05-19-2014, 04:36 PM   #7
Richard Grasa
Richard Grasa's Avatar
Drives: Work truck
Looks that way to me as well. I would do the same and also clean out the chip with a q-tip soaked with some IPA (isopropyl alchohol, aka rubbing alcohol) for good measure just be be sure it completely clean.
Richard Grasa is offline   Reply With Quote
Old 05-19-2014, 04:48 PM   #8
BRZ_Kamil
Okay thanks guys! Ill do this tomorrow! Ive also heard of mixing the clear and the base coat.. idk if i should do this or separate?
Old 05-19-2014, 04:48 PM   #9
BRZ_Kamil
@Richard Grasa @cnk
Old 05-19-2014, 04:56 PM   #10
cnk
I believe the Subaru paint is supposed to be used as a a base and then clear on top of it. I would not mix the two.
Old 05-19-2014, 05:25 PM   #11
Richard Grasa
Drives: Work truck
Do it separate. You want to put on a couple thin coats of base, enough to hide the primer and anything else that's different than the white and then fill up the rest of the chip with a few light coats of clear. One tip I can give you is don't use the brush that usually comes with the touchup, it's not that accurate and tends to glob the paint on. Instead use a small artist brush.
Old 05-19-2014, 07:34 PM   #12
BRZ_Kamil
Could i use a tooth pick or sometbing like that? Ive seen,people do,that. They just dab the paint on it when its a really small chip
Old 05-19-2014, 08:05 PM   #13
Richard Grasa
Drives: Work truck
Yes, anything you are comfortable with that you can most accrately apply the paint with. Its hard to tell how big it is from the pic so I suggested the artist brush.
Old 05-19-2014, 10:23 PM   #14
BRZ_Kamil
its REALLY small like smaller than the tip of an eraser
Paint Chip Woes onetime4 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 05-22-2015 06:37 PM
Paint chip fixes kchkwan Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 46 04-04-2015 01:16 AM
Paint chip/scratches davidchoi Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-04-2013 03:21 AM
Paint Chip :( jlu Southern California 11 01-22-2013 03:32 AM
Small paint chip frosty86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 12-01-2012 12:31 AM
