Northwest AK, ID, OR, WA
Old 05-13-2014, 03:08 PM   #1
Shaisters
Resident Wookie
Drives: 2013 SWP Limited BRZ
Air Filter Replacement
Since I didn't get much help with a post in the DIY section I figured I'd see if any of you know, or could help out. I installed my new filter over the weekend, and fit everything back together quite nicely. The only thing I noticed was after installing the airbox back into the snorkel there seemed to be a small gap visible between the box inlet and the snorkel outlet (photo attached). I'm not sure if it was like this before, but the car is definitely running better than with the stock filter so I don't think it's a big deal and is still sealing properly.
Shaisters is offline   Reply With Quote
Old 05-13-2014, 03:36 PM   #2
ramiram1984
Drives: 2016 STi DGM
Sometimes takes patience and little elbow grease
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 05-13-2014, 03:41 PM   #3
Shaisters
Resident Wookie
So there should be no gap visible? I'll unbolt it and redo it today at work if that's the case.
Old 05-13-2014, 03:55 PM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
No gap. Force it in there.
Old 05-13-2014, 06:17 PM   #5
Churnobyl
Churnobyl's Avatar
Drives: 2014 Limited Subaru BRZ DGM
Took me a couple tries on mine to get the fitment aligned so that everything fit together correctly. I ended up pulling off the 3 (I think) retaining bolts to give me the needed room to lift the filter housing out, position it correctly and then reassemble. Even though I was able to remove the stock filter with everything bolted together.
Churnobyl is offline   Reply With Quote
Old 05-13-2014, 06:22 PM   #6
Shaisters
Resident Wookie
In that case it shall be done, just need to undo the 3 bolts and live by my friends gear assembly motto. "Don't fit? Force it."
Old 05-13-2014, 06:39 PM   #7
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Mine has the gap, as long as the foam on the snorkel is still in contact with the airbox there should be absolutely no functional issues.
Decay107 is offline   Reply With Quote
DIY Cabin Air Filter Inspection/Replacement F1point4 DIY (Do-It-Yourself) Guides 137 08-12-2023 06:32 PM
DIY: Drop-in Air Filter Replacement Rabble DIY (Do-It-Yourself) Guides 68 09-01-2022 07:12 PM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Simple drop-in filter replacement? CaptainSlow Engine, Exhaust, Transmission 3 04-22-2013 11:41 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
