Drives: 13 frs
FRS tire jack
has anybody had to use the jack in trunk to change tire.
well had a bad expiriance this morning trying to put the spare on could not get the car high enough with that jack. car fell twice .had to call roadside ass.hour later came with floor jack to put spare on. ps.car was in my garage with flat floor! |
Drives: 2014 BRZ MT (Sold); 2006 V70R
Where are you placing the jack? I haven't looked at my jack yet, but I'd imagine that it is supposed to secure in one of the weld points. Look at owners manual to determine where to use it. Also, make sure e-brake is engaged, else car may roll and fall over.
You should have no problems w/ the stock jack unless your car is raised... o.O |
Drives: Scion FR-S
Any mods to your suspension?
Drives: Scion FR-S
I'm going to go out on a limb and guess OP was jacking at the front floor jack point or diff and not the pinch welds. Correct me if I'm wrong.
Turbo E85
Drives: 13 wrb brz
buy a harbor reight floor jack cost. less than 80$.. the best one is 130$ super low profile
Turning is for Nerds
Drives: 35 characters is not enough
I have used the factory jack to swap tires out at an HPDE (actually I used two simultaneously to lift up half of the car), no issues here.
Drives: '13 DGM BRZ Limited
I had to use mine to change my driver's side rear tire after a puncture. I'm lowered 1" on KW V3's and had no issue using the factory jack.
Drives: 2013 Subaru BRZ MT Limited
Used mine on the side of the highway last summer when I got a flat...no issues. You're doing it wrong bro...
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
When In Doubt...
Drives: Slowww
In to find out what OP believes is the correct way to use this jack.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#10 |
Drives: Scion FR-S
Before I got a low profile jack, I used the factory jack emergency jack all the time because it was the only thing that fit. I've never had any problems with it. I am also in to see how OP is jacking up his car.
2013 Ultramarine FR-S 6MT
#11 |
Explain more of the situation, maybe something was done incorrectly or the jack could be faulty... Sometimes en exercise in frustration can leave you blind to the obvious. The factory jack isn't ideal, but it works fine if used correctly and the car is on a stable, grippy surface.
Where was the jack located to lift the car? Was the jack groove placed directly on the pinch weld? Were you on soft terrain like sand, gravel, or mud? (edit, nevermind just noticed you said you were in a garage) Slippery snow/ice? Which tire were you trying to change? Was the handbrake fully engaged? Were you trying to lift the rear end, possibly causing both rear wheels to get "light"? Any suspension mods? Was anyone in the car holding the brake pedal? Since the car is rear wheel drive, one rear wheel needs to be well weighted on the ground to prevent rolling movement, or someone needs to sit in the car with the brake pedal depressed. If only the front wheels are on the ground, you risk the car rolling in ANY situation, even in a level garage, unless you chock the wheels (wedge something under them to prevent rolling). |
#12 |
Drives: 2013 Scion FR-S - Argento
Used the trunk jack in this car and others a bunch of times with no issues. Use it on the side pinch welds like the manual says and on hard ground (asphalt, cement, or at least really hard dirt).
I've never called for roadside ass before though, I just wait til I get home! |
#13 | |
Drives: 2014 FR-S 6MT Whiteout
Or you could use a wheel chock or two. Which is what you should do.
#14 |
| $10 Jack Buddies | blalor | DIY (Do-It-Yourself) Guides | 24 | 10-20-2017 07:16 PM |
| Bad Emergency Jack? | JDMenrique | Issues | Warranty | Recalls / TSB | 35 | 11-27-2015 07:55 PM |
| JACK's BRZ! | Mr. Jack | Member's Car Journals | 10 | 07-05-2013 09:19 AM |
| Where ti jack car up at? | skatery1989 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-13-2012 01:53 AM |
| Jack Spots? | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 06-11-2012 09:09 AM |
