Old 06-07-2012, 05:43 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Jack Spots?
Where have you guys been putting the jacks at? On the passenger side I can use the frame rails. But the drivers side has the plastic skid plate on the frame rail covering it.
Also jack stands I didn't really see a ideal spot to put them at.
feldy is offline   Reply With Quote
Old 06-07-2012, 05:49 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Jackstands go in the same spot as almost every other modern car, between the two half moons on the other rocker joint/whatever it's called near the outside of the cars.
Rear center jack point = diff
Front center jack point is normally the subframe, but it's covered.. soo.. not sure.
I never use the frame rails, I've seen far too many bend in.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-07-2012, 05:49 PM   #3
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Rear differential and front subframe. See attached file.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 06-07-2012, 05:53 PM   #4
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I would not use the frame rails to jack the car. For putting the jack stands, yes I believe that is an acceptable location.
Looking through the manual last night, the front has a cross member piece that has a circle on it. From the front view, it almost looks like:
Code:
|xxx|------| |-----|xxx|
|xxx|------\o/-----|xxx|
|xxx|       ^      |xxx|
           Here
I believe there is something similar in the rear. I remember on the Si, the rear tow hook was the jacking point!
EDIT: Yes, it is the differential in the rear. As uneasy as that makes me.. I suppose it's solid and can handle the weight.
eriktherod is offline   Reply With Quote
Old 06-07-2012, 07:04 PM   #5
dsgerbc
Drives: BRZ(sold), STI
Search, lol.
dsgerbc is offline   Reply With Quote
Old 06-10-2012, 02:45 AM   #6
AzFranz
Az to Nm to Az
AzFranz's Avatar
Back end isn't that heavy so I assume the rear diff is just fine. The front is what spooks me. I see the spot they are talking about, but I hesitate. Will take this one slowly.
AzFranz is offline   Reply With Quote
Old 06-10-2012, 01:32 PM   #7
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
i have a lift so, :P lol i win!
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-11-2012, 08:50 AM   #8
blalor
Drives: WRB BRZ Limited 6MT
Is there some kind of pad you put between the jack stands and the jack point? At a quick glance, the jack point was just coated a little heavier than the rest of the underside…
blalor is offline   Reply With Quote
Old 06-11-2012, 09:09 AM   #9
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
I use hockey pucks when lifting cars with my Bend Pak lift.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Good Floor Jack Suggestions was385 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 53 05-23-2014 03:56 PM
GTA Meeting Spots Brainstorm Dragon86 CANADA 33 06-20-2012 09:22 PM
Video: Jack Hollis and his FiveAD FR-S poormans_LFA FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 05-22-2012 06:07 PM
Questions for VP of Scion Jack Hollis. SpeedR Scion FR-S / Toyota 86 GT86 General Forum 79 04-08-2012 07:51 AM
Blind Spots? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 35 10-04-2011 03:17 PM
