Old 01-04-2014, 04:57 PM   #1
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
Won't go into first when hot and in traffic
Hey guys
Sometimes when I'm driving in deep traffic I'll try to put the car in first gear but I get locked out. I tried having the dealer look at it but they couldn't replicate the problem.
So anyone else experiencing this?
mrha is offline   Reply With Quote
Old 01-04-2014, 05:07 PM   #2
Red FRS
Red FRS's Avatar
Drives: 2014 Subaru BRZ
When the car is moving or stopped?
Because I believe you aren't supposed to put it into first if you're going fast than 5 mph...
Molded rb v1 BRZ on WCI LP1
instagram.com/seantejani
Red FRS is offline   Reply With Quote
Old 01-04-2014, 05:11 PM   #3
kthxbai
kthxbai's Avatar
Drives: '13 Whiteout FR-S M/T
Agree with this except not sure on the actual speed. If your car is rolling in traffic, there is no need to go to first. It places unnecessary stress on the transmission and engine, don't do it unless after you come to a complete stop
s3 Tapatalk
kthxbai is offline   Reply With Quote
Old 01-04-2014, 06:56 PM   #4
ktech
Drives: '13 BRZ Ltd, 6MT
Have noticed what OP is talking about; not really a temp issue, but when going over a certain speed it is difficult/impossible to go in to first (like when coasting in to a stop sign, I would try to put it in first preemptively; no longer).
Just uh, don't put it in first until you're going slow enough. Worked for me!
ktech is offline   Reply With Quote
Old 01-04-2014, 07:09 PM   #5
serith
serith's Avatar
Drives: 2009 Scion tC RS 5.0
Use 1st gear when the car is completely stopped. If you're already moving use 2nd.
09 RS 5.0 -- #862 of 2000 -- 5spd
serith is offline   Reply With Quote
The Following 3 Users Say Thank You to serith For This Useful Post:
Marchy (01-06-2014), nightsmoke (01-04-2014), SirBrass (01-07-2014)
Old 01-04-2014, 08:05 PM   #6
onabulletride
onabulletride's Avatar
Drives: 14 brz
What everyone else said. Also double clutching usually makes it easier to get into first.
onabulletride is offline   Reply With Quote
Old 01-04-2014, 08:09 PM   #7
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
I downshift into first at like 15mph sometimes. Pretty sure there's no lockout...
Ganthrithor is offline   Reply With Quote
Old 01-05-2014, 12:25 AM   #8
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
i know exactly what you are talking about OP.
in order to disengage the 'lock', tap your gas pedal, as RPM goes a bit up, it will slide right into 1st gear
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 01-05-2014, 03:18 AM   #9
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Always rev match. Every gear. Especially a downshift to first!
ashtray is offline   Reply With Quote
The Following User Says Thank You to ashtray For This Useful Post:
Old 01-05-2014, 03:36 AM   #10
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
Why would you ever need to downshift into first?
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 01-05-2014, 04:29 AM   #11
Ganthrithor
Because there's a stopsign handy and I want to practice for slow corners? I didn't think downshifting to first was a real thing either until I drove Pike's Peak. When you're entering a 15mph, steep, uphill corner at 9,000 feet, you really don't want to take it in second :3
I've started doing it all the time for my driveway here at home, too-- it's transition from a steep hill onto an even steeper driveway end and has a not-so-great transition that you really want to take slowly to avoid scraping or just upsetting the car as you accelerate up it. You can do it in second-- barely-- but you really lug the engine doing it. The car is much happier in first.
It's really not much harder than downshifting to any other gear once you get used to it. You just need to be a little more precise with your rev-matching than usual.
Old 01-05-2014, 09:59 AM   #12
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
The following is a comment that is inappropriately applied to the OP's question because it applies to a specific situation that the OP did not describe. It therefore may imply to some other readers that shifting into first gear "... at like 15mph sometimes..." is advisable.
In this case when one states a procedure in their initial post one should explain the circumstances. In this case, describing that it was a Pike's Peak situation and not a common driving habit.
BRZfan is offline   Reply With Quote
Old 01-05-2014, 02:12 PM   #13
SeanBlader
Drives: Suburu BRZ Limited, black
I've had the same problem climbing Mount Hamilton in a mark one MR2. Switchback, uphill, at granted less than 9000 feet, you really need to be in first gear to get out of the turn. I'd recommend rev matching, and/or double clutching. If you're on the flat, and don't need a lot of power, just go to second gear.
SeanBlader is offline   Reply With Quote
Old 01-05-2014, 05:15 PM   #14
Ganthrithor
Ummmm it was in direct response to this dude:
...who implied that there's a speed-related lockout on first gear? There is no such thing; that's all I'm saying. If the OP is getting locked out of first gear then something is Wrong(TM).
Traffic Tickets Anyone? SocalBurt Scion FR-S / Toyota 86 GT86 General Forum 325 04-18-2016 06:51 AM
Pioneer traffic tuner Tdot CANADA 1 12-13-2012 07:59 PM
photoblockers for traffic camera tnt Scion FR-S / Toyota 86 GT86 General Forum 22 08-22-2012 11:05 PM
Dangerfield is in the traffic newft86 AUSTRALIA 12 06-25-2012 08:57 PM
Traffic Nav Not working on my BRZ Indestruct Electronics | Audio | NAV | Infotainment 9 06-19-2012 09:38 PM
