Old 05-07-2014, 12:20 PM   #1
shif7i7down
Erected Member
Drives: frs
Final Drive and speedometer question
I want to change the stock 4.10 FD for a Mfactory 4.67FD sold by ft86 speed factory, and i just want some confirmation.
I've searched the forum and from what I've gathered, the frs doesn't get its speedometer reading from the transmission but instead gets its from the wheels, so..
If i were swap to the 4.67 i shouldn't have to worry right?the speedometer should still read correctly?
Thanks in advance
shif7i7down is offline   Reply With Quote
Old 05-07-2014, 03:47 PM   #2
PantsDants
Drives: Scion FR-S A/T, Whiteout
Thanks in advance
Yep, speedometer readout is unaffected.
PantsDants is offline   Reply With Quote
Old 05-07-2014, 04:47 PM   #3
shif7i7down
Erected Member
Drives: frs
thanks, and is this from personal experience?
Old 05-07-2014, 09:01 PM   #4
PantsDants
Yep, I wrote a parts list for it here:
http://www.ft86club.com/forums/showthread.php?t=49288
Old 05-07-2014, 09:09 PM   #5
shif7i7down
Erected Member
Drives: frs
Does the mark 3 supra ring and pinion really fit in the frs deferential? Awesome
Old 05-13-2014, 12:36 PM   #6
shif7i7down
Erected Member
Drives: frs
does anyone know where or IF there's a taller 6th gear set that i could buy? for MT
also: since the transmission is made by Subaru, if there's any known possiblity of interchangeable gears from other Subaru trannys.
Old 05-13-2014, 01:17 PM   #7
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
The transmission is NOT made by Subaru so the answer to your question is "no." The twins' transmission is made by Aisin.
^GT5 Replay Photo Mode^
Old 05-13-2014, 02:18 PM   #8
shif7i7down
Erected Member
Drives: frs
if that's the case then NVM.
I was hoping to that the FRS might share some similar size gear but with different ratio with other cars so i could have a taller gear swapped in for my 6th gear.
Old 05-13-2014, 02:37 PM   #9
SirBrass
SirBrass's Avatar
You can probably get a racing transmission shop to make you a longer 6th gear.
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 488 06-17-2018 12:14 AM
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 10:18 PM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
Anyone w/ 3.727/3.909 Final Drive Post Boost? Staf00 Engine, Exhaust, Transmission 12 05-02-2013 08:38 PM
