Old 05-01-2013, 06:28 PM   #1
Staf00
Drives: SWP DZE
Anyone w/ 3.727/3.909 Final Drive Post Boost?
Title says it all. Just wondering if anyone with forced induction has installed a taller (or is it shorter?) final drive gear. I ask because I would considering it when I get the Vortech kit. Not really aiming for high MPGs or anything, but a 3.909 would at least get u past 60mph in 2nd. At the same time, I fear the 3.727 would rob you of too much acceleration. Just looking for some thoughts & feedback.
Staf00 is offline   Reply With Quote
Old 05-01-2013, 07:10 PM   #2
Pete
Pete's Avatar
Drives: 22 BRZ
I was just thinking the same thing for my vortech kit yesterday, I would like to have a bit more play in 1st 2nd & 3rd. Interesting topic.
Pete is offline   Reply With Quote
Old 05-01-2013, 07:24 PM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
or you could save money and raise the limiter past 8k that way you'll hit 60 in 2nd
Old 05-01-2013, 09:09 PM   #4
mrk1
Drives: Sterling BRZ Ltd
Turbo could go lower but a centifugal SC like the vortech would benefit from a bump up, 4.44 or 4.55
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-01-2013, 09:57 PM   #5
roddy
roddy's Avatar
Drives: '13 Ultramarine
Agreed. Generally speaking, turbos like a higher (lower numbers) gear. It helps build exhaust pressure to spin up the turbo. Centris like a lower (higher numbers) gear. It helps get the RPMs (and boost) up earlier. Positive displacement blowers aren't as fussy, but sure are a hoot to drive with a lower gear...
Old 05-01-2013, 10:50 PM   #6
OrbitalEllipses
Drives: Attitude
Spinning engine rotating assembly possibly higher than they were meant to spin (no, an article quoting an STI employee is not good enough) to an unknown end is not "saving money" compared to a taller final drive.
Old 05-02-2013, 04:22 AM   #7
Staf00
Drives: SWP DZE
This discussion has been quite insightful, I'm glad we had it. After considering how turbo/centrifugal sc reacts to a final drive change, I'm thinking of just keeping it stock lol. I don't really wanna cruise at 4k on the freeway and yet pretty much been persuaded from going 3.727/3.909 so staying 4.1 I guess.
Old 05-02-2013, 07:59 AM   #8
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Don't forget to consider any tire changes that will effect the "resultant" final drive ratio.
Stock tires (215/45-17) and stock rear gears (4.10) will result in 3000 rpm @ 70mph
Going to a 235/35-17 set up will will result in 3150 rpm @ 70 mph
Keeping the stock tires with 3.909 gears will result in 2870 rpm @ 70 mph
Going to a 235/35-17 & 3.909 set up will will result in 3000 rpm @ 70 mph, same as stock. You will have spent a lot a money to achieve the same result as doing nothing.
Gary in NJ is offline   Reply With Quote
Old 05-02-2013, 08:09 AM   #9
zooki
Drives: waiting on a 2021...
Keeping the stock tires with 3.909 gears will result in 3870 rpm @ 70 mph
I think your math is wrong. Going with 3.909 gears instead of the stock 4.10 gears will result in lower RPM at 70 compared to stock.
New gear ratio/old gear ratio x RPM
3.909/4.10 x 3000 = 2860 RPM not 3870.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 05-02-2013, 08:59 AM   #10
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
I don't have any trouble at all hitting 60mph in second!
Scott
naikaidriver is offline   Reply With Quote
Old 05-02-2013, 09:02 AM   #11
Gary in NJ
Gary in NJ's Avatar
TYPO, should be 2870. Thanks for letting me know. I fixed it above.
Old 05-02-2013, 08:26 PM   #12
Staf00
Drives: SWP DZE
Thanks, I kept tire sizes in mind. I intend on going 225/40R18 on all 4 corners, which is just a smidge larger diameter than stock. Not really trying to build a dedicated track car, but just for street instead. Do you guys think 225s would be too skinny w/ RE-11 or AD08 or something along that tier? I'm sure they've dropped in price since the RE-11A & AD08R came out recently.
So using the formula above...
70mph w/ 225/40R18 & 4.10 final drive would result in ~2944rpm
70mph w/ 225/40R18 & 4.44 final drive would result in ~3188rpm
70mph w/ 225/40R18 & 3.909 final drive would result in ~2807rpm
Btw, has anyone figured out how to calibrate the speedometer to compensate for different tire sizes?
Old 05-02-2013, 08:38 PM   #13
OrbitalEllipses
Drives: Attitude
Performance summer tires tend to run wide, so remember that. My 225/45 Pilot Super Sports aren't pinched on a 8" wide rim, but do poke a bit at the bead.
As far as the speedo is concerned, you need a module that intercepts the VSS signal. DCCD Pro/Spiider was working on this a few years ago in the Impreza world, I'd check with him. Really it's not a big deal as long as you stay within 3% of the original tire diameter.
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 488 06-17-2018 12:14 AM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
First Post - First Drive - First Love Skin Scion FR-S / Toyota 86 GT86 General Forum 8 07-10-2012 09:13 PM
