Old 04-05-2013, 01:45 AM   #1
wootwoot
Drives: FRS
Final Drive Calculations
There are a few final drive upgrades available for our cars. My question is how do you calculate the increase in "power" for the various ratios? For example, how much more power will you gain at the wheels with a 4.4 final drive vs a 4.7 final drive?
wootwoot is offline   Reply With Quote
Old 04-05-2013, 01:52 AM   #2
whataboutbob
AutoX-10/10ths every run
I am interested in this too.
Build thread:Here
Old 04-05-2013, 02:52 AM   #3
u/Josh
Drives: GBS Limited 6MT
I think 4.1 FD is stock. In that case,
For 4.4:
4.4/4.1 = 1.07
For 4.7:
4.7/4.1 = 1.15
So the 4.4 FD and 4.7 FD would put out 7% and 15% more torque than stock respectively at a given RPM and in a given gear.
Be careful with this mod if you are an autocrosser, as it would significantly shorten second gear and possibly require a lot more third gear shifts.
u/Josh is offline   Reply With Quote
Old 04-05-2013, 03:28 PM   #4
wootwoot
Drives: FRS
Thanks for the info Josh. This is mostly an everyday/weekend car but I plan to get it out to the track a few times this season. Not all that interested in autocross. I think I can live with the change in gearing in terms of cruising around. I figure stock I am at 2100rpm at 70mph in 6th. With the 4.7 I would be at 2600rpm at 70mph in 6th (I think). That doesn't sound too bad to me in terms of everyday drive-ability. Opinions are welcome, however.
Assuming 150rwtq that means about 10ft/lbs with the 4.4 and about 22ft/lbs with the 4.7. Sounds fun to me!
Old 04-05-2013, 03:44 PM   #5
u/Josh
Engine speed would go from 2100 rpm to (2100*1.15=) ~2400 rpm. I know someone has already installed a different final drive and their review was very positive if I remember correctly.
Old 04-05-2013, 03:56 PM   #6
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You don't gain power at the wheel you gain torque. It is just a multiplication ratio.
So whatever torque you get at the rear diff, multiply it by 4.7 instead of 4.4. I suck at math but this is how it works.
Engine torque * current gear ratio * differential ratio = Wheel torque
Rayme is offline   Reply With Quote
Old 04-14-2013, 03:38 PM   #7
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
http://www.ek9.org/forum/transmissio...st-friend.html
here you go
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 04-14-2013, 03:50 PM   #8
Opposed
Drives: 2013 Asphalt FR-S
I know this is a big argument, but you won't see any increase on a dyno. I went from the stock 4.10's to 4.77's on my s2000 and dyno'd both on a Dynojet and the numbers were the exact same.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 04-14-2013, 06:22 PM   #9
WatchmaN
WatchmaN's Avatar
I thinks to see the increase on a dyno you have to keep 4.10 on the dyno setting. But you did see an increase on your butt dyno no?
Old 04-14-2013, 07:50 PM   #10
Opposed
Yes and no. It was def quicker around town, especially with dealing with the low torque that car had. But after about 60-70 a stock one could pull on me because of the taller gear and torque advantage in the upper RPM band. I really enjoyed them for the most part. Only disadvantage is if you are a highway driver. That car with 4.77's was turning around 4k RPM's at 60 MPH, 5500 at 80.
Old 04-14-2013, 10:43 PM   #11
Captain Insano
That last part surprises me. Seems like you would pull on a stock car in any gear until you hit the Rev limiter.
Old 04-15-2013, 08:13 AM   #12
Opposed
It does seem that way. There is a huge mathimatical explenation to it on the S2k forums. But I am far from a mathimatical guy. So it's difficult for me to explain.
Old 04-15-2013, 11:48 AM   #13
wootwoot
Drives: FRS
That surprises me as well. I thought it would give you the same increase in torque throughout the rpm band. From all reports I have read that is the case anyway. It would seem to me that if the more aggressive final drive was running at a higher RPM at any given MPH over the stock final drive the more aggressive final drive would be faster until it tops out.
Example: In an FRS with a 4.55 FD you should be around 3400 RPM at 70 MPH. The stock 4.10 should be at 2900 RPM at 70 MPH. Just looking at the RPM's, the 4.55 should be able to pull on the 4.10 at 70 MPH because the car makes more power at 3400 RPM then it does at 2900 RPM. The gearing advantage should, in my mind, amplify this effect further.
If I am wrong, what am I missing?
Old 04-16-2013, 03:36 PM   #14
wootwoot
Drives: FRS
No one else?
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 488 06-17-2018 12:14 AM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
Final Fantasy jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 66 08-25-2013 10:31 PM
Suspension Calculations mla163 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-18-2012 11:30 PM
