Old 05-05-2014, 08:18 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Installing Resonator?
I've had my Tsudo catback exhaust 2.5" for awhile and kinda want to try tweaking it to make it sound different and drop the dBs a little bit. Anyone have any experience with Vibrant Resonators? Tsudo's layout is just a straight pipe from the catback to the muffler, no resonators.
[ame="http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Dautomotive&field-keywords=Vibrant%20Resonator%20"]Amazon.com: Vibrant Resonator: Automotive[/ame]
I'm looking at the 1141 (2.5" "Ultra Quiet Resonator") and the "Bottle style resonators" 1790, 1791, etc. Don't really know what to expect from any of these. Would these significantly reduce dBs or would they only change the tone? How much should I expect to pay to have a shop weld it in?
l0aded is offline   Reply With Quote
Old 05-05-2014, 08:24 PM   #2
Panda Mao
Panda Mao's Avatar
Drives: 2014 Scion FRS
from my experience the longer the resonator the more effective it has on lowering db's also the raspy is reduced too but u need at least 1-2 resonators to drop anywhere from 1-5 db's from my experience
Panda Mao is offline   Reply With Quote
Old 05-05-2014, 09:12 PM   #3
l0aded
Addicted
l0aded's Avatar
So basically I shouldn't expect a radical change?
Old 05-05-2014, 09:49 PM   #4
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
I was thinking of the HKS dual resonator front pipe for mine. Right now my setup is Borla UEL, 2.5 over pipe, 2.5 Berk front pipe with highflow cat. & Invidia N1. I little to much above 4,000 rpm's :-(
zoth is offline   Reply With Quote
Old 05-05-2014, 10:24 PM   #5
Panda Mao
Panda Mao's Avatar
also if the exhaust comes with optional silencers that usually means the aftermarket mufflers arent quiet enough for sound dampening but its also usually off road oriented more or less. there are some exhausts that doesnt use detachable silencers those usually have a more street legal sound system under 95 db that or install resonators which adds a tad more weight.
if you have to use an extra resonator dont use magnaflow their resonators weigh about 10 lbs at least it was the biggest mistake I made wen i bought one for my ford probe years ago thing was heavier than my borla exhaust all together ><
Old 05-05-2014, 10:51 PM   #6
l0aded
Addicted
l0aded's Avatar
Would something like this even fit on the exhaust with the heat shields?
[ame="http://www.amazon.com/Vibrant-1141-Ultra-Quiet-Resonator/dp/B000E3VHWI/ref=sr_1_3?ie=UTF8&qid=1399344554&sr=8-3&keywords=vibrant+resonator"]Amazon.com: Vibrant 1141 2.5" Ultra Quiet Resonator: Automotive[/ame]
Dimensions on the website say: 4 1/2" x 6 3/4" x 14" overall length
Reviews look pretty phenomenal and weight is 5 lbs so not too bad.
Old 05-05-2014, 10:58 PM   #7
Panda Mao
Panda Mao's Avatar
I wouldnt know I havent installed a cat back exhaust yet still running on stock im just saving up 1200-1300 bucks for the hks Ti-L exhaust
Old 05-19-2014, 09:31 PM   #8
l0aded
Addicted
l0aded's Avatar
Bump.
So I looked under the car and the Vibrant Ultra Quiet Resonator would not fit at all. Anyone have any experience with aftermarket glasspack (bottle style) resonators?
I am looking at the Vibrant 17930 which has a 5" diameter but is only 18" long vs. the MBRP R1016 which is 4" in diameter but 26" long. There are good reviews from Vibrant but would with a much shorter length would it not be as good?
Links:
MBRP 4x22: [ame="http://www.amazon.com/R1016-Outlet-Overall-Stainless-Resonator/dp/B000OAZCW2/ref=sr_1_7?s=automotive&ie=UTF8&qid=1400549113&sr= 1-7&keywords=mbrp+resonator"]Amazon.com: MBRP R1016 2.5" Inlet/Outlet 22" Body 26" Overall Length T304 Stainless Steel Resonator: Automotive[/ame]
Vibrant 17930: [ame="http://www.amazon.com/Vibrant-17930-Outlet-Stainless-Resonator/dp/B0038HRNZ2/ref=sr_1_1?s=automotive&ie=UTF8&qid=1400549488&sr= 1-1&keywords=Vibrant+17930"]Amazon.com: Vibrant (17930) 2.5" Inlet/Outlet 18" Long Stainless Steel Resonator: Automotive[/ame]
Old 05-19-2014, 09:47 PM   #9
l0aded
Addicted
l0aded's Avatar
Doing a volume calculation with V=(pi)*(r^2)*L of the two seems like the 5" diameter has more volume which should equate to more deadening.
If you include the 2.5" flow it's V= 353.4 (5x18") vs 326.7 (4x26")
If you minus the 2.5" flow the effect is amplified being V= 88.356 (5x18") vs 45.9 (4x26")
All in cu in.
From what I understand about the glasspack bottle resonators there are a lot of factors but volume is important since it's packed with fiberglass deadener. Am I on the right track with these calcs?
Old 05-19-2014, 10:01 PM   #10
Brick
Drives: White 2013 FRS
A true resonator isn't filled with anything. I had a vibrant resonator on my beetle when it had the 13B in it and it cleaned up the sound a lot and will reduce the volume a bit. On the FRS there is a noticible change between the non resonated Perrin and the resonated Perrin. You will notice a difference.
Brick is offline   Reply With Quote
Old 05-20-2014, 01:43 AM   #11
l0aded
Addicted
l0aded's Avatar
Went with the Vibrant one since it has a better name. I'll do some dB recording before and after to see the difference
Old 05-20-2014, 01:49 AM   #12
eighty666
why not have the shop switch out your mufflers for something like flow master quiet flow
eighty666 is offline   Reply With Quote
Old 05-20-2014, 01:52 AM   #13
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
I had that Vibrant 2.5" installed on my TRD catback. It REALLY cut the noise down to the point where its nice and quiet in the cabin, but its still audible when I step on it. Its also much quieter at startup/idle.
The actual exhaust note DID change a bit, its not as burbly before and more high strung. So keep that in mind, it might change how the exhaust actually sounds.
But I am happy with it. This is my daily driver exhaust, and I still have my stock midpipe with the nameless muffler delete for when I feel like it LOL
Kostamojen is offline   Reply With Quote
Old 05-20-2014, 03:36 AM   #14
l0aded
Addicted
l0aded's Avatar
I wish I could run your setup but unfortunately Tsudo decided to offset the midpipe slightly to the left so it can't fit the Vibrant Ultra Quiet Resonator.. Hopefully the bottle style one will have a similar effect.
Intake resonator?? DIE1000DEATHS Engine, Exhaust, Transmission 16 12-03-2014 08:17 PM
Perrin CBE with resonator ZZT86 AUSTRALIA 11 04-09-2014 05:00 AM
Removing The Resonator Nicolas0esp1 Engine, Exhaust, Transmission 12 01-22-2014 02:52 PM
Intake resonator delete. mid_life_crisis Engine, Exhaust, Transmission 2 09-12-2013 09:14 PM
Exhaust Resonator Brndn704 Engine, Exhaust, Transmission 3 08-20-2013 02:31 PM
