Old 04-27-2014, 02:49 PM   #1
BRZnut
Drives: BRZ DGM Limited
Found the source of a rattle, and fixed it!
Since new, there has been a ticking sound that seemed to be coming from the drivers door when going over imperfections in the road. After spending 1.5 years trying to find the source from the door, I realized yesterday that it is coming from the driver's side pillar! (the pillar where the seat belt attaches to)
There are two pieces for plastic on the pillar. The upper one where the belt attaches does not move. But the lower piece (about 1/2 way down) has too much play. I caulked the gap between the two, and the sound is gone!
Drove today with no click click click!!!
Old 04-27-2014, 10:26 PM   #2
CrazyClover
CrazyClover's Avatar
Drives: 2013 FRS RAVEN
Wait you only have one rattle...lol. Great find I'll be checking if that's the source of any noises I hear.
CrazyClover is offline   Reply With Quote
Old 04-28-2014, 05:42 AM   #3
speedrye
Drives: White
Did you use Window & Door caulk, or just a generic silicone caulk?
speedrye is offline   Reply With Quote
Old 04-28-2014, 12:01 PM   #4
SSchifko
Owner and Operator
SSchifko's Avatar
Drives: FR-S, Yamaha R6, 1972 Camaro
I had a popping/ rattle when I hit tiny bumps too. Turned out the rear fender was popping at the crease. I pulled the fender liner out and gave it a tiny hit with a hammer in the crease and no more pop. Weird bubble.
-Schifko
SSchifko is offline   Reply With Quote
Old 04-28-2014, 12:20 PM   #5
FRiSson
Drives: FR-S MT
I get a gentle rattling/buzzing coming from the dash at speed. Usually it goes away when I open the glove compartment. Please note that the sound occurs even when the glove compartment is in closed position and has been emptied . Anyone get this?
FRiSson is offline   Reply With Quote
Old 04-28-2014, 10:45 PM   #6
BRZnut
No this was one of many, and all have been fixed with clear latex caulk:
All plastic panels around the wheel wells have been caulked and then sprayed with under coating.
Wires in the trunk secured so as not to rattle with small amounts of caulk.
Wires under the front dash (driver side) caulked to prevent movement.
The panels under the car which gave a rattle at highway speed..you got it....caulked.
Currently I am 100% rattle free with reduced road noise.
Old 04-29-2014, 12:03 AM   #7
poison1916
Drives: Scion FR-S Hot Lava
Turn your stereo up, duh. Wubwubwub.
Sent from my HTC6525LVW using Tapatalk
poison1916 is offline   Reply With Quote
Old 04-29-2014, 12:25 AM   #8
TimeForLove
Drives: 2013 BRZ 2001 Impreza RS
Thanks! Guess I need to start caulking lol.
TimeForLove is offline   Reply With Quote
Old 04-29-2014, 04:13 PM   #9
phuthinhon
Drives: 13 BRZ
I have the same thing. Where is the area that you fixed exactly? Not sure where the rear fender at the crease is...
phuthinhon is offline   Reply With Quote
Old 04-29-2014, 04:55 PM   #10
GremlinGSP
I just got a loud exhaust to solve the rattles and a loud stereo to fix drone.
GremlinGSP is offline   Reply With Quote
Old 05-08-2014, 10:39 PM   #11
SSchifko
Owner and Operator
SSchifko's Avatar
Sorry for the delayed response. Refer to the photo. I pulled the plastic fender liner out and around the inside of the fender is another metal panel.
The inner metal panel and rear quarter meet at that edge. I could actually get a 'pop' if I pushed on the rear quarter by the door. The area I circled was where the bubble was but on the underside. Not on the outer body panel. So my tap with the hammer was not to a panel that is seen from the outside.
-Schifko
Solution Found: Rear Deck Rattle jdubz Issues | Warranty | Recalls / TSB 29 10-13-2019 02:48 PM
Solution Found: Rear Deck Rattle jdubz DIY (Do-It-Yourself) Guides 31 08-23-2015 05:08 PM
Loud Underbody *Rattle* Defect Found - Easy Fix Anorexic 86 Issues | Warranty | Recalls / TSB 32 11-12-2014 10:26 PM
SOURCE,LLC xia User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-28-2013 02:21 PM
HID source in GTA wbradley CANADA 2 08-12-2012 10:09 AM
