Old 10-13-2012, 10:12 AM   #1
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
Loud Underbody *Rattle* Defect Found - Easy Fix
The (#3) underbody panel that mounts around the exhaust pipe rattles like mad because some of the bolts were designed to hold 2 larger and wider underbody panels together on both sides... instead of just one slimmer unit (#4) attached on the driver side.
This issue ONLY affects FR-S/BRZ/86 models that DO NOT come with the extra underbody panels pictured below...
The North American and entry level models DO NOT get the long wider underbody panels and THAT'S THE PROBLEM!
The (3) bolts on the LEFT SIDE (passenger side) and the (1) bolt on the TOP RIGHT (driver side) are too long and cause the (#3) panel to rattle.
Pictured below: Japanese high end model with the extra panels all bolted together.
CHEAP FIX: Install a 3/8" washer on each of the above mentioned bolts to fill in the extra void (you cannot simply tighten the bolts any further without installing new washers... the threads don't extend all the way to the bolt head). I personally bought four 3/8" nylon washers (about 2mm thick) from a hardware store and installed one on each bolt... NO MORE RATTLES!
Other option: purchase and install the extra Japanese panels.
Anorexic 86 is offline   Reply With Quote
The Following 5 Users Say Thank You to Anorexic 86 For This Useful Post:
Blue86 (10-13-2012), brichard0625 (10-13-2012), carbonBLUE (10-13-2012), flippy (11-12-2014), zoomzoomers (11-05-2012)
Old 10-13-2012, 10:42 AM   #2
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Hmm this must be what I'm hearing during first start up
Tt3Sheppard is offline   Reply With Quote
Old 10-13-2012, 11:11 AM   #3
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Good find i was having the same noise during start up and accelration at low rpms. I knew it had to be something underneath the car.
brichard0625 is offline   Reply With Quote
Old 10-13-2012, 02:04 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
I'm not so sure if this is the rattle that some of us hear at low RPM under load - that sounds more like a metallic rattle, this material is some kind of a composite, no?
In any event, I do see what you mean - the bolts are easy to get to without jacking up the car too, so I might look into putting some washers in there. Anyone know what size is best?
Old 10-13-2012, 02:07 PM   #5
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Good find! I do not notice it on my car, even when it was up on the rack. But something to keep in mind. I would really like to add the other panels to mine eventually.
Picture shows a 10mm bolt, so I would expect a washer for a 10mm bolt to work fine.
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 10-13-2012, 03:08 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
I don't think it's a standard bolt - looks like it has a ring piece between the bolt head and the threaded shaft and it's wider than the threaded shaft. I think we would want the washers to go around that part and not the threaded shaft. I'll yank one off and bring it into Home Depot with me.
Old 10-13-2012, 03:13 PM   #7
Neziah
yeah, best idea yet. Let us know what you figure out.
HotLava FRS MT
Old 10-13-2012, 05:20 PM   #8
gmookher
neoprene washer perhaps?
gmookher is offline   Reply With Quote
Old 10-14-2012, 03:32 PM   #9
Foobar
SLO NO MO
Foobar's Avatar
Found some 3/8 washers that fit perfectly. I had to double up the one on the passenger side closest to the driveshaft as it was still loose with only one washer.
Old 10-18-2012, 11:10 AM   #10
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
can someone repost the pictures from the OP?
ap5512 is offline   Reply With Quote
Old 10-18-2012, 11:29 AM   #11
brichard0625
Old 10-18-2012, 11:33 AM   #12
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
are you anorexic sti from iwsti?
VSGTS14 is offline   Reply With Quote
Old 10-18-2012, 12:12 PM   #13
ap5512
ap5512's Avatar
dafuq..why can't i see any pics?
Old 10-18-2012, 04:00 PM   #14
alrashwa
alrashwa's Avatar
Drives: '12 370Z Monterey Blue
Hah, I was wondering what that sound was. Usually happens during a cold start, loud rattle for about 30 seconds, then quiets down when the RPM settles. Good find, I'll have to try it.
alrashwa is offline   Reply With Quote
Solution Found: Rear Deck Rattle jdubz Issues | Warranty | Recalls / TSB 29 10-13-2019 03:48 PM
Solution Found: Rear Deck Rattle jdubz DIY (Do-It-Yourself) Guides 31 08-23-2015 06:08 PM
SOUND LEVEL TO LOW!! Not loud enough Hbomb Electronics | Audio | NAV | Infotainment 24 12-21-2012 10:02 AM
Repair Process on This OEM Defect Tanuki Issues | Warranty | Recalls / TSB 192 12-17-2012 06:35 PM
Underbody cladding Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 8 08-16-2012 02:12 PM
