Old 04-22-2014, 05:29 PM   #1
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
Rear window still fogs up after strut caps were installed
Last spring after purchasing the car, I noticed the rear window would fog up pretty quickly no matter the conditions outside. After peering around this forum, I found that a lot of dealers were forgetting to place the rear strut plugs before delivering the car to the customer. Well mine was one of those cars. So the dealer went ahead, installed the plugs after a month or so of rainy spring driving.
For the last 6 months or so, the car was parked in my garage till the snow melted away and we got a good rain to wash away all the road salt.
Well the window still fogs up!
So now all I can think about is how much rust or mold is growing in the rear hatch
DoctorNick is offline   Reply With Quote
Old 04-22-2014, 05:42 PM   #2
andrew20195
Drives: 2013 Subaru BRZ
Strut plugs? Are you talking about the holes on top of the rear shocks? Technically, the car isn't supposed to have anything there. The body plugs that are part of PDI are the ones under the car in the rocker panel area.
Is that fog on the inside of the glass or outside? If so, do you have any moisture in your taillight lenses? If you don't have the updated taillight seals it may be entering through that area.
That being said, I just replaced my seals due to taillight moisture, but I've never had condensation on the inside of the rear glass.
Edit: Also check under your spare tire and see if there's evidence of water pooling up there, if you haven't done so. Sometimes you can see a dust trail that will point you in the right direction.
andrew20195 is offline   Reply With Quote
Old 04-22-2014, 05:53 PM   #3
AznBRZer
Drives: 16 CBS WRX Limited
There's an old thread about this issue. It's leftover residue from something on the glass from assembly. Get some glass cleaner to clean it and it should go away.
AznBRZer is offline   Reply With Quote
Old 04-22-2014, 06:50 PM   #4
andrew20195
Good point. I was assuming it's moisture, but it could be "vinyl fog".
Clean it real well with glass cleaner and paper towels until a dry towel doesn't want to slide across the glass, i.e., it's hard to wipe due to friction. If that fixes your problem, that's what it was.
Old 04-22-2014, 07:13 PM   #5
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
Ah yes, it was the body plugs I was talking about. Wasn't sure of the technical name. The fog is on the inside. I will give the glass cleaner a try.
Thanks!
Old 04-22-2014, 07:31 PM   #6
Muskokan
Drives: white Sport-tech
Maybe dirty mike n the boys used your car over the winter... Smell like shame when you first got in?
Muskokan is offline   Reply With Quote
Old 04-26-2014, 05:39 PM   #7
foompla
Drives: hot lava frs
This.
foompla is offline   Reply With Quote
Old 04-26-2014, 08:17 PM   #8
BRZnut
Drives: BRZ DGM Limited
my rear glass looks the same..I just figured it was off gas from the plastics
Wiring BRZ rear fog light to only come on with front fogs Scenic Driver DIY (Do-It-Yourself) Guides 4 09-12-2015 09:36 AM
Winjet Fogs & Headlights installed! BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 3 04-29-2014 02:58 AM
HELP!!! Fog lights....LED DRL Fogs vs. Projector Fogs w/ Halo tiz22 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-02-2013 01:57 PM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
