Old 01-17-2014, 01:17 AM   #1
BMHumanic
Drives: 2013 Whiteout 6MT FR-S
Winjet Fogs & Headlights installed!
Just finished installing my Winjet Foglights to go with the headlights I got a month or so ago. They look absolutely beautiful! Bit confusing of an install, and definitely need to know your way around car electronics (also helps having small hands to fit in tight spaces). Absolutely love them, totally worth the money! Check out my Instagram @ItsFRShh for more pics!
Wanted to thank my fellow SoCal Valley 86 members for getting these in our hands first
BMHumanic is offline   Reply With Quote
Old 01-17-2014, 12:12 PM   #2
sirsol66
Drives: 2013 FRS- Hot Lava
Curious, how did you wire up the actual switch? I'm curious where you tapped it into.
Also, where did you run the main wire into the cabin from?
sirsol66 is offline   Reply With Quote
Old 01-17-2014, 03:27 PM   #3
BMHumanic
The switch its self plugs into a factory blank by the trunk button. The ground is secured to a bolt nearby. For the power to the button its self I ran an extended wire through the car and out the passanger side firewall, and wired it strait to the battery. The lights themselves are wired directly to the battery as well. I didn't want to splice or tap any wires in order to keep it removable if need be.
Old 04-29-2014, 02:58 AM   #4
WWShehan
WWShehan's Avatar
Drives: Hot Lava Orange - 2013 FR-S
I know this is old but i just got my winjet fogs as well and i was wondering if there is a DIY somewhere that i haven't found or what? I'm pretty much a noob to wiring things :/
WWShehan is offline   Reply With Quote
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 10:24 PM
Winjet headlights fogging up? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 23 05-17-2014 01:26 PM
Winjet Headlights - Installed, Compared, and done up the FT-86 SpeedFactory Way! FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 42 03-24-2014 11:08 PM
*Phastek* Winjet Coverage @ SEMA 2013 - JDM Replica Headlights, Fogs, Tails PhastekSport Cosmetic Modification (Interior/Exterior/Lighting) 82 03-09-2014 12:32 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
