Old 05-25-2013, 09:42 PM   #1
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Wiring BRZ rear fog light to only come on with front fogs
I didn't want mine to always be on with the tail lights or function as a brake light. The wiring for the front fogs are at the main body ecu behind the lower dash panel. It was raining on and off and I was working outside so sorry for the lack of pics of how to run the wire from the dash to the rear fog.
Here's a pic with the connector already removed.
The left & right fogs are on separate circuits, I wired mine to the left hand one. Here is the connector diagram, wire 3 is for the LH fog light, the wire is red with a white stripe. 5 is for the RH fog light, the wire is white with a red stripe. Connecting here will put it after the fog light fuse so no additional fuses are needed.
To remove the dash panel, remove the panel on the side of the dash and remove the philips screw under that panel and the one at the lower right of the lower dash panel, then the panel can be pulled off. For instructions on removing the interior panels in order to run the wire, download the service manual for the FR-S or BRZ, there are great diagrams with locations of all of the clips. There is a factory channel for wiring under the carpet along the door sill.
Scenic Driver is offline   Reply With Quote
Old 05-25-2013, 09:47 PM   #2
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Beat me to it! Appreciate the post!
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-12-2014, 12:09 AM   #3
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
So there's no way to wire that closer to the rear, we have to run a wire all the way to the front ? Just asking !
Simon99 is offline   Reply With Quote
Old 03-12-2014, 06:34 PM   #4
ScorpionOzzy
Drives: Scion FR-S
Glad to see someone did this right! I was never a fan of having that thing come on with the brake lights.
ScorpionOzzy is offline   Reply With Quote
Old 09-12-2015, 09:36 AM   #5
Papi
Drives: Crystal White Silica BRZ Limited
So how's the fog light working out
Papi is offline   Reply With Quote
Fr-s Spyder tail light wiring. ettorres15 Southern California 4 04-17-2017 12:31 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
rear brake light in the rear fog light section FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 34 12-13-2012 10:52 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
