Old 04-22-2014, 04:18 AM   #1
ayau
Drives: Some rust bucket
MY2015 suspension bolts
MY2015 is supposed to include a couple new suspension bolts to stiffen up the chassis. The only difference I can tell is the flange size. The new bolts have a thicker flange.
See post below.
http://www.ft86club.com/forums/showp...9&postcount=48
The part numbers are as follows.
Toyota/Scion
SU003-05212 x 4
SU003-05213 x 2
SU003-05235 x 2
Subaru
901000431 x 4
901000435 x 2
902350032 x 2
A quick Google of the part numbers shows that these new bolts aren't available in North America yet except for the nuts on the rear shock. They use the same nut as the current models.
The Following 6 Users Say Thank You to ayau For This Useful Post:
Boxer486 (04-22-2014), civicdrivr (05-19-2014), Createddeleted (04-22-2014), Guillaume (05-13-2014), Superhatch (05-13-2014), Valentino (07-07-2015)
Old 04-22-2014, 04:24 AM   #2
ayau
Upon further research, I'm not so sure if these bolts were meant to stiffen up the chassis or just a cover up the weakness of the old bolts.
A Japanese blogger went ahead and swapped his old bolts for the MY2015 bolts. One of the pics shows what seems to be a broken bolt. Looks like the flange was rusted off? I'm assuming the new bolt is at the top and the old bolt is at the bottom.
Maybe the old bolt has a collar. Like those Spoon Rigid Collars used to stiffen up the subframe. Not sure. Can anyone confirm?
Source: http://ameblo.jp/zn6-86-fa20/entry-11827527447.html
The Following User Says Thank You to ayau For This Useful Post:
Old 04-22-2014, 04:27 AM   #3
wootwoot
Drives: FRS
Just looks like a washer to me....
JDM bolts yo!
wootwoot is offline   Reply With Quote
Old 04-22-2014, 04:29 AM   #4
ayau
JDM bolts yo!
Yeah, that's what I'm thinking too. No way a two year old bolt could rust and break off like that lol.
Old 04-22-2014, 05:57 PM   #5
xwd
I saw Revolutions started selling some bolts, probably the same crossmember bolts.
They also started selling a reinforced front crossmember.
Old 05-13-2014, 01:17 PM   #6
Guillaume
Guillaume's Avatar
Drives: Exige S 240
How is this thread not more popular?! Thanks OP!
Old 05-13-2014, 01:48 PM   #7
ayau
I just called Subaru and they have all those parts in stock now. I also verified that the USDM 2014 models use the updated bolts. Ordered a set. Will be picking them up soon.
Old 05-13-2014, 09:35 PM   #8
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
Anyone know the build dates this started with?
Proof is offline   Reply With Quote
Old 05-15-2014, 01:26 AM   #9
cslntuee
Drives: Subaru BRZ Limited
Are these same as STI one?
http://www.ft86club.com/forums/showp...&postcount=612
Thanks.
cslntuee is offline   Reply With Quote
Old 05-15-2014, 01:35 AM   #10
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by cslntuee View Post
no. the locations are different.
the MY2015 ones are for front subframe and at rear lower arm where the rear strut joins.
Nardi330 is offline   Reply With Quote
The Following User Says Thank You to Nardi330 For This Useful Post:
cslntuee (05-15-2014)
Old 05-16-2014, 04:44 PM   #11
Dezoris
Dezoris's Avatar
Post up when you get them and post differences.
I replaced most of my suspension bolts last year already when I did suspension work. Would like to see the differences.
Old 05-16-2014, 06:03 PM   #12
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Does that collar get reused on to the new bolt? Without that collar it looks like it would create slop between the bolt->subframe. Since the diameter of the new bolt is the same as the old one.
So has anyone said that their 2014 handles different then a 2013? (since it apparently uses the new bolts)
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 05-16-2014, 06:24 PM   #13
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
http://www.ft86club.com/forums/showp...6&postcount=93
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
SpeedyJay (05-16-2014)
Old 05-16-2014, 06:51 PM   #14
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
^Interesting
Looks like a decent upgrade,
Tial BOV bolts Sportsguy83 Forced Induction 6 04-14-2014 02:49 PM
WTB Camber Bolts JS + BRZ Want-To-Buy Requests 6 03-07-2014 08:18 PM
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 10:00 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
seat bolts? zooki Cosmetic Modification (Interior/Exterior/Lighting) 3 08-29-2012 07:00 PM
