Old 04-20-2014, 10:36 PM   #1
kingkai23
Drives: 13 swp limited
running e85 without flexfuel kit?
Im going to be installing my jdl kit soon..i have a e85 station 5 miles from my house, can i get tuned for e85 without flex fuel kit , i really dont need 2 maps or is flexfuel kit reccomended..i dont wanna spend extra $ if i dont have too i dont drive my car in winter so im not worried about cold start issues..i gotta order my injectors still and a fuel pump i just hope i dont have to order a flexfuel kit as well..i tried searching but couldnt find any answers
kingkai23 is offline   Reply With Quote
Old 04-20-2014, 10:46 PM   #2
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
If you will be running exclusively E85 you don't need flexfuel, although it is better for the fuel system to occasionally run a cycle of pump gas. Also with the variation of quality of E85 day to day and station to station you might want a more conservative tune, as well as keeping your eye on your afr after each fill up when going wot while the ECU "learns"
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 04-20-2014, 10:46 PM   #3
14BRZ
14BRZ's Avatar
Drives: 2014 BRZ, 08 CBR600RR
It isn't absolutely necessary, but if you have a tune for 91/93 pump and a tune for E85, you will need to run the tank to almost empty for either to work alone without a flex fuel kit. Flex fuel kit just makes it more convenient to add E85/91/93 at any time without the tank being completely empty since it adjusts the fuel trims/maps automatically.
If you plan on running E85 full time, you can get a tune just for that and be ok if you don't plan on running 91/93 pump gas. But if you plan on switching between E85 and pump gas, the tank will need to be next to empty before switching maps.
14BRZ is offline   Reply With Quote
Old 04-20-2014, 10:47 PM   #4
s2d4
s2d4's Avatar
Well, if you are going to be running E85 at all times from the same station and you don't fill up winter blend, provided you have a good tune, no need for it.
Old 04-20-2014, 10:52 PM   #5
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
An ECA is nice at a minimum to know your percentage of ethanol.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Old 04-20-2014, 10:55 PM   #6
kingkai23
Thanks fellas for quick replys
Old 04-21-2014, 07:06 AM   #7
xjohnx
Grip>Slip
xjohnx's Avatar
As someone who ran E85 w/o a flex fuel kit for about a year, here are a couple other things that haven't been mentioned:
If you plan on any road trips, be prepared to spend time researching E85 locations along your route and chart out stops for fuel along the way, don't forget to account for a slightly shorter range on e85 than you may be accustomed to with pump gas.
I would also recommend picking up a manual ethanol content tester. It's basically a little test tube you mix with part water, part ethanol, shake, and then read the ethanol content based on how the water/gas separates. Each time you fill up try to get a sample and log the ethanol content somewhere so that you can keep an eye on it for consistency, although fuel trims should compensate it's good for peace of mind.
Old 04-21-2014, 11:02 AM   #8
xwd
With as much money as you are spending already might as well throw in a FF kit. I recommend the Moto-East.
Old 04-21-2014, 12:00 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Or simply bring the laptop with a 93 octane tune ready to load. Flashing the ECU at the gas station should only take a couple minutes.
Old 04-21-2014, 12:07 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Or have a different map for 93 and switch with CC stalk/defrost button.
FlexFuel and Facts Shiv@Openflash Software Tuning 74 05-07-2025 04:28 AM
Screencast: flexfuel with racerom jamesm Software Tuning 7 02-05-2014 10:58 PM
FlexFuel over Straight E85 on EcuTeK, why is it better? DeliciousTuning Software Tuning 37 12-17-2013 10:21 PM
questing on going with a flexfuel tune yetiFR-S Engine, Exhaust, Transmission 3 11-22-2013 08:17 AM
Flexfuel Allch Chcar Scion FR-S / Toyota 86 GT86 General Forum 50 11-04-2011 12:39 AM
