Screencast: flexfuel with racerom
[ame="http://youtu.be/rD3zZ_tQHQg"]http://youtu.be/rD3zZ_tQHQg[/ame]
| The Following 7 Users Say Thank You to jamesm For This Useful Post: | 1stGenBRZ86 (02-05-2014), marcosowns (02-05-2014), mkivsoopra (02-04-2014), SmsAlSuwaidi (02-05-2014), Sportsguy83 (02-05-2014), tg_1981 (02-04-2014), u/Josh (02-04-2014) |
Drives: GBS Limited 6MT
These videos are great.
One kind of off topic question though, why can/do you target a leaner (equivalent) AFR with E85? |
#3 | |
in lambda: gas: rich best torque is 0.85, lean best torque is 0.9 e85: rich best torque is 0.714, lean best torque is 0.867 i typically shoot for around 11.6-11.8:1 on e85 for a boosted application, where i'd normally target 10.8-11.2:1 on 93. others go even leaner. i tend to be very conservative with my tunes. those last couple hp aren't worth tuning into knock and/or leaner than i'm comfortable with, to me at least. of course with e85 there is little to no risk of knock under load, but still better safe than sorry
| The Following User Says Thank You to jamesm For This Useful Post: | Sportsguy83 (02-05-2014) |
That makes sense to me under heavy load, but at cruising load where knock isn't an issue and the gas tune is already quite lean, is it safe to lean it out still another point on E85?
I messed up in the video, there's a load threshold on the map to keep it from effecting open loop or lower loads. Gotta edit that
. You could definitely run gas equivalent 15.7:1 in cruise no problem won e85 though, from what I've read. Never tried it myself.Alternatively use could use load on one axis of the custom map to vary it that way. |
| The Following User Says Thank You to jamesm For This Useful Post: | u/Josh (02-05-2014) |
Boosted
Drives: Not a supra....yet
why use coolant temp ( complete tuning noob )
No good reason. Just an example. In the video I also suggest using rpm or load. Also manifold pressure is a good option, whatever you find useful to solve any problem you may be needing to solve. That's the power of racerom. You can literally do it any way you like almost without limitation.
In many cases the second axis isnt used for anything, like on the case of the fuel volume comp in this map. With further tuning we'd change it to be whatever we find necessary, when a problem arises that needs solving
I Love custom Turbo kits
Drives: Limited BRZ
The tune being used is so much full of WIN!
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | jamesm (02-05-2014) |
| FlexFuel and Facts | Shiv@Openflash | Software Tuning | 74 | 05-07-2025 04:28 AM |
| Screencast: Innovate LC1 logging with RaceRom | jamesm | Software Tuning | 7 | 12-27-2013 06:59 PM |
| Screencast: quick look at BRZEdit af/ignition learning view | jamesm | Software Tuning | 1 | 12-26-2013 01:36 AM |
| Screencast: racerom custom maps overview | jamesm | Software Tuning | 5 | 12-22-2013 02:06 PM |
| Flexfuel | Allch Chcar | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 11-04-2011 12:39 AM |
