Old 04-18-2014, 04:55 PM   #1
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Stock Map Sensor Rating
Hi, I am having the Innovate Supercharger installed on my car and the tuner offered to sell me a 2.5 bar map sensor. I am only running max 12psi so do I need this or will the stock sensor do? Thank you.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 04-18-2014, 05:29 PM   #2
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Innercooled or no? There was some problems with the MAP signal breaking up past 4000 rpm on inner cooled setups, along with other oddities. http://www.ft86club.com/forums/showthread.php?t=40066
I originally started with a 4bar sensor, but ended up flipping back after discussion with two different tuners. I'd recommend reading through that thread for more info.
mikalem is offline   Reply With Quote
Old 04-20-2014, 12:27 PM   #3
jjkerr626
jjkerr626's Avatar
No my setup is not inter cooled, it does have the Raceseng 70mm pulley. What do you think? Thanks.
Old 04-20-2014, 12:37 PM   #4
nelsmar
Any links to actual references. That thread is over 100 pages.
And to the op it depends on your tuner. The map sensor is used to offset injector compensation for manifold pressure but there are other ways of doing things. Just depends on what your tuner is doing.
My flickr - Canibeat
Local magazine scout
Old 04-20-2014, 12:37 PM   #5
350matt
Drives: toyota mr2/ Toyota GT86
I think the stock sensor is a 2Bar unit so nominally works at 1Bar on the NA engine so ostensibly you can read a bar of boost (14.7 psi)
however in reality the sensor will probably start to clip the signal before this and become non linear at the top end as these sensors aren't meant for boost pressure
I'd fit the Omni item as thats a direct replacement and a 3bar item
350matt is offline   Reply With Quote
Old 04-20-2014, 12:40 PM   #6
nelsmar
Oem is 1.67 iirc.
Old 04-20-2014, 01:06 PM   #7
mikalem
mikalem's Avatar
Sorry about that, but if memory serves it was moto-mike and group that was having the problem with the sensors inner-cooled: http://www.ft86club.com/forums/showt...40066&page=178
There's also reasoning in that thread from other tuners: http://www.ft86club.com/forums/showp...postcount=4096
It's a long thread but there is a ton of info in there about the system and all of it's potential configurations - I highly recommend reading through it.
Old 04-20-2014, 01:20 PM   #8
nelsmar
Thanks I appreciate it! I heard about issues but I haven't seen the actual posts. I have read through some of it but really 100+ pages is really something that is hard to casually read up on LOL!
Old 04-20-2014, 03:35 PM   #9
350matt
1.67 Bar only?
blimey that needs changing right off then
Old 04-20-2014, 04:35 PM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
1.67 Bar only?
Why? The OEM sensor runs the car fine on the Sprintex kit. It's not like a turbo where boost measurement is required. The only thing you lack is a boost reading from the OBD port above the sensor's range.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-21-2014, 05:12 PM   #11
350matt
Hmmm
Ok if you're running the car in MAF centered mode then yes the OEM MAP sensor will be fine as its not used for the primary calibration
however this means each cal for this configuration will need the MAF meter scaling quite a lot and may possibly clip its output at higher airflow / power levels
the industry standard is usually to run the MAF as the secondary sensor with the MAP sensor as the primary
ie running the engine in speed density mode
hence my comment of requiring a new MAP sensor with an appropriate sensor range
Stock BRZ/FRS Wheels. SoCal Perfect Condition. No Tires No Sensor. Dwood11 Wheels and Tires 5 03-04-2014 09:47 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 07:16 AM
