Old 03-08-2014, 05:24 PM   #1
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
FRS Bumper alignment issue, help please
Hey,
So I've had my bumper replaced on my FRS and after that I've taken my bumper on off several times for headlight modifications, I noticed a slight gap on the passenger side by the headlight, I'm not 100% sure if this was like this before or when I re-installed the bumper I didn't clip it back in properly, anyways, now if I try to push on that area to try and clip it in, nothing happens and it just comes back out..
Just wondering if anyone else experince a similar problem and has any suggestions on how to correct the problem?
I hope I don't need a new bumper.. I've attached 2 pictures below.
Thanks!
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-08-2014, 06:34 PM   #2
grostoine
Drives: Subaru BRZ
remove your bumper, you put it wrong.
I had similar issue with my bumper. I remove it and notice there was a small parts of plastic that were crush...
grostoine is offline   Reply With Quote
Old 03-08-2014, 06:36 PM   #3
Brody602
Drift King
Brody602's Avatar
So take it off and then straighten out the pieces that are crushed? My car is parked for the winter so i won't be able to tackle this until the snow melts :-/
Old 03-08-2014, 07:01 PM   #4
grostoine
Drives: Subaru BRZ
Watch those plastic clip under the headlights when you can. They are the caused off your bumper misalignment !
Old 06-04-2015, 01:18 PM   #5
namele55
Drives: frs
I'm having the same issue. The auto body shop I used to repair my car did a shit job. I went back twice and this guy cant put the bumper on correctly. Are those brackets replaceable?
namele55 is offline   Reply With Quote
Old 06-04-2015, 02:27 PM   #6
Brody602
Drift King
Brody602's Avatar
No, they are plastic tabs that are part of the bumper itself. It's a pain in the a** to get them to go in properly once they've been force-pushed on improperly :/
Driver door alignment issue--fixed kingping Issues | Warranty | Recalls / TSB 14 03-26-2019 09:46 AM
Fender alignment issue - Bowing out smellslikecurry Issues | Warranty | Recalls / TSB 14 02-01-2014 12:44 AM
BRZ front bumper fitment issue Thongpocket Cosmetic Modification (Interior/Exterior/Lighting) 0 10-21-2013 02:23 PM
Rear fog light bumper issue Sniper2606 Cosmetic Modification (Interior/Exterior/Lighting) 3 09-27-2013 04:15 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 07:34 PM
