Old 04-05-2014, 04:46 PM   #1
junior_reyez
Drives: 2014 Scion Fr-s FireStrom
Alignment Help Needed
So I have ST coilovers w/ Enkei Kojins 18x9.5 45+ offset square set up so my next step was to go get my alignment now Toyota says I need control arm because camber and there unable to do anything without new control arm ? Is this true or is there another way to avoid buying another part .. The only issues there having is in the rear
junior_reyez is offline   Reply With Quote
Old 04-05-2014, 04:51 PM   #2
junior_reyez
Posted in wrong area please delete MODS sorry !
Old 04-05-2014, 08:58 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yes. There is no camber correction from the factory. You need aftermarket lower control arms or the adjustable upper control arm bushing from whiteline (they are a pita though). Unless you are ocd and need it even or it is over 2° it should be fine as is. Just make sure your toe is zeroed.
Sent from my LT30at using Tapatalk
Old 04-05-2014, 09:40 PM   #4
junior_reyez
So what do you recommend ? Thanks so much for the help
Old 04-06-2014, 02:00 AM   #5
E46toFT86
Drives: IB '05 E46 M3 ZCP
Like others have stated there is no adjustability with the stock control arms. Buy the cheap/decent SPC LCA's that have +/- 2 degrees of camber adjustment for ~$195 and call it a day.
'05 Interlagos Blue
E46toFT86 is offline   Reply With Quote
Old 04-06-2014, 03:01 AM   #6
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
I have some gold j2 lca new for sale just saying
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 04-06-2014, 03:03 AM   #7
sosick
fastest frs in sbg
sosick's Avatar
2014 firestorm frs
Old 04-06-2014, 03:05 AM   #8
sosick
fastest frs in sbg
sosick's Avatar
Same set on my car
2014 firestorm frs
Old 04-06-2014, 03:08 AM   #9
junior_reyez
How much ?
Alignment help needed DeaconRoc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-07-2013 02:30 AM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Avoided deer, spun out, alignment needed? gatorbushmen Scion FR-S / Toyota 86 GT86 General Forum 30 07-28-2013 11:14 AM
wheel alignment needed? j2digit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-10-2013 05:32 PM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
