Old 07-26-2013, 11:13 PM   #1
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Avoided deer, spun out, alignment needed?
Those damn deer.....
Long story short, I was taking a friend home, saw a deer hop out in front of me, swerved to avoid it, spun out and ran straight into the grass. Luckily, there was no curb, just a bunch of grass. I heard a pop come from the front of the car.
After post-spin out inspection, I noticed that the car pulled right if I put the steering wheel in the straight position. I am assuming I broke something, since I heard the popping noise. Im gonna jack her up tomorrow, any ideas on what I need to be looking for? Steering knuckle? I really do not know, but I doubt an alignment will fix my problems. The front wheels dont have any visible positive camber, so it has to be something that bent or broke.
Any help would be appreciated.
gatorbushmen is offline   Reply With Quote
Old 07-26-2013, 11:28 PM   #2
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
take to a specialist and have them put it on the rack for the alignment and have them inspect it at the same time. Mine only cost 60.00
Customize the piss out of it and call it yours!
Skywgn1 is offline   Reply With Quote
Old 07-26-2013, 11:30 PM   #3
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Jack up the front of the car and take off both wheels. Inspect the front spindles and then the two arms for their attachment points to each other and the chassis. Then carefully examine the tie-rods and the steering rack; be sure to look over where/how the rack mounts to the chassis.
If you broke/bent something it should be fairly obvious
When is doubt take it to a competent shop and have them put it on the rack
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 07-26-2013, 11:37 PM   #4
gatorbushmen
Amateur Drifter
Drives: '13 FRS
Thanks guys, I love this community. so helpful!
Ill keep you guys updated..
Old 07-26-2013, 11:41 PM   #5
whaap
whaap's Avatar
If it acts differently after the incident than it did before you know something is wrong. I wouldn't bother inspecting it. Get it to an alignment shop to be checked. You might have a bent suspension part that will need replacing. At the very least you will need an alignment.
whaap is offline   Reply With Quote
Old 07-26-2013, 11:50 PM   #6
Captain_Awesome_Pants
Captain_Awesome_Pants's Avatar
Drives: FR-S: Firestorm
Agree with this 100%. "Just grass" can do a LOT more damage than you think. Especially with hidden mud, rock, debris etc... Might have a damaged part.
Captain_Awesome_Pants is offline   Reply With Quote
Old 07-27-2013, 12:03 AM   #7
d4wt
d4wt's Avatar
Drives: a couple + an frs
glad you're okay. while luckily there was no curb or worse another car around, swerving under such a circumstance is usually not the best approach. sure, we are all "great drivers" but it's small mistakes like this that can end up costing you a lot more than an inspection and a few parts
d4wt is offline   Reply With Quote
Old 07-27-2013, 12:19 AM   #8
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
this. thankfully there was grass next to you, but sometimes the best scenario is to just hit the animal.
bkblitzed is offline   Reply With Quote
Old 07-27-2013, 09:52 AM   #9
FRyeS
Drives: 2013 FR-S Asphalt 6MT
Don't veer for deer!
FRyeS is offline   Reply With Quote
Old 07-27-2013, 11:44 AM   #10
whaap
whaap's Avatar
Originally Posted by Marchy View Post
my buddy is an insurance adjuster and he always says to hit the animal and don't swerve. hitting the animal removes you from fault and won't affect your insurance rates as much as avoiding it and essentially crashing yourself.
LOL. I'd rather pay for an alignment or a bent control arm than drive around a car that's had patched up sheet metal and paint.
p.s. I retired after 25 years of handling automobile insurance claims.
Old 07-27-2013, 12:14 PM   #11
whaap
whaap's Avatar
or pay for an entire car had there been a rock, or a ditch, or a telephone poll. I'll stick to hitting the animal.
That's sort of a 'duhhhh'. If I don't have an escape route I agree with you. The topic on this thread is a guy who missed an animal by going off into some grass which, again, is the option I'd take any day. What you would decide to do might be different and that's o.k.
Old 07-27-2013, 01:27 PM   #12
gatorbushmen
Amateur Drifter
Drives: '13 FRS
So I haven't gotten the chance to jack up the car, but I figured out by using a level, that I have some toe-out on the front right wheel.
Now I am no suspension buff, but I am assuming I'm dealing with either a bent tie-rod or steering link.
I did some research, maybe a bushing for the steering link caused the "popping" noise that I heard when I spun into the grass..... I dont know, a friend is dropping off his jack stands so i can take a closer look.
Since I am dealing with toe, what part would I be limited to? Or could it be a plethora of things since there is a great possibility that I bent something...?
Old 07-27-2013, 01:41 PM   #13
namdoog
Drives: Crystal Black Silica BRZ
It could be a plethora of things. Could be as easy as adjusting the toe back where it needs to be... could be a bushing, rod, or control arm.
Is there any unwelcome vibration right now when you drive?
namdoog is offline   Reply With Quote
Old 07-27-2013, 01:58 PM   #14
kcam86
Drives: Asphalt FR-S MT
I work at Beaver Toyota I can probably get my buddy to put it in the shop to look at it for next to nothing if you want and get you employee pricing for an alignment. If you want to be my "cousin".
kcam86 is offline   Reply With Quote
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
wheel alignment needed? j2digit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-10-2013 05:32 PM
Spun out now a CEL Noob4Life Issues | Warranty | Recalls / TSB 10 03-30-2013 11:02 PM
avoided near serious accident with my FR-S jflogerzi Scion FR-S / Toyota 86 GT86 General Forum 9 07-02-2012 02:48 PM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
