Old 04-02-2014, 08:21 PM   #1
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Stock brakes worn out?
I've now got 27k or about 16k miles for y'all muricans....
Winter driving my car so well, but it definitely feels like braking performance has decreased. May be the snow tires too.
What's your guys experience with this?
Considering changing the pads but I don't know if it's necessary...
Brahsbrah is offline   Reply With Quote
Old 04-02-2014, 08:35 PM   #2
CSG David
CSG David's Avatar
Just pop off your wheels and check the thickness of your pads.
Old 04-02-2014, 09:15 PM   #3
Brahsbrah
Going to do this once it gets a bit warmer.
I don't think they could be worn out already...
Old 04-02-2014, 09:17 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
how hard are you braking
now that the temps are warming, panic/hard stops on snows are gonna have you plow quite a bit
Old 04-02-2014, 09:35 PM   #5
Brahsbrah
When I press lightly on the brake. Seems like it used to grab harder, but I'm thinking you may be right.
Old 04-03-2014, 11:28 AM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
tires are also probably a big part of it...and you can bleed your brakes too
Old 04-03-2014, 11:57 AM   #7
wparsons
wparsons's Avatar
Tires have no effect on how much initial bite a pad feels to have.
Glazed pads, air in the lines or worn pads or defective memory ( ) could make them feel like they have less bite.
flickr
Old 04-05-2014, 12:45 AM   #8
Brahsbrah
What benefit does that have other than getting rid of bubbles.?
Old 04-05-2014, 01:08 AM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Air in the system makes your brake pad spongee.
Over time your brake fluid absorbs moisture from the air because brake fluid is hygroscopic.
By getting rid of this air and having pure brake fluid, you get better braking.
Also -- Braking distance is mostly on the tire...
N1rve
Stock brakes too small for stock wheels ndsleep612 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 04-11-2014 09:24 PM
Stock brakes too weak? Alabang BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 111 09-13-2013 04:41 PM
Worn out clutch stopper AsianStyle Issues | Warranty | Recalls / TSB 1 07-05-2013 07:07 PM
What's everyone doing on stock brakes, for pads? Nourdmrolnmt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 05-15-2013 05:08 PM
Worn Clutch? Jakeedaman21 Issues | Warranty | Recalls / TSB 18 04-30-2013 02:06 PM
