Old 04-23-2013, 05:14 PM   #1
Jakeedaman21
Drives: Ultramarine FR-S M/T
Worn Clutch?
Starting information I suppose.. This is my first MT, though I am not a hooligan with it.
I recently moved from California to a northern state, and on the way passed through San Francisco. After the move there is around 9000 miles on my FRS.
On a (quite large) hill in SF, I accidentally let the car rev very high while letting out the clutch too slowly, noting a burning smell. Since then I have babied it even more than usual, but the characteristic of my shifts has changed. Before, it was very clunky going from 1st to 2nd, and had a "snappy" grab point. Now it is extremely smooth, without any clunking going between 1st and 2nd, and it has a wider grab point. It feels mushy.
Does this mean I ruined my clutch, or am on the way to doing so? Could it be the change in altitude (sea level to 3300ft) or average temp (50-80 in California to always below 20-40 up north)? Could it be it has just settled in after a long break in? Do I need to replace it?
Thank you in advance, and for understanding my inexperience in the subject.
Jakeedaman21 is offline   Reply With Quote
Old 04-23-2013, 05:22 PM   #2
was385
Drives: MT WRB BRZ Limited, 2007 911s
It may be a combination of you getting smoother with your shifts and your fear of screwing something up convincing you it feels much different than normal.
was385 is offline   Reply With Quote
Old 04-23-2013, 05:26 PM   #3
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Assuming you're still under warranty, I'd take the car to the dealership and have them assess it. It's possible that you have worn it, but having a clutch replaced under warranty might be tough with certain dealerships.... since it is considered a "wear and tear" part.
gatorbushmen is offline   Reply With Quote
Old 04-23-2013, 05:34 PM   #4
KSC
KSC's Avatar
Drives: Ion Redline
Well, that's a new one. Someone who wants the clunky 1/2 shift. Damned if you do...ect.
Seriously, though, sounds like the clutch has worn in, not out. Also, if you're babying it now, you're probably shifting slower and involuntarily pulling the shifter towards your body, this getting a smother shift. Warmer weather will make it feel smoother as well.
In short, one clutch ride, mishift, grind, ect isn't going to ruin a clutch straight out. You're fine, Id say.
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 04-23-2013, 05:43 PM   #5
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
try to do acceleration test.
you must know how the car responded before.
If engine is screaming while not picking up speed then clutch is worn.
gzpermadi is offline   Reply With Quote
Old 04-24-2013, 07:41 PM   #6
Jakeedaman21
The vehicle seems to accelerate around 20-25% slower from what it used to. Also seems that i has lost a bit of torque on the low end. Mushy...
Old 04-24-2013, 08:42 PM   #7
KSC
KSC's Avatar
Drives: Ion Redline
Get it checked out then. Can't imagine a single incident causing this, though. New MT drivers would be replacing clutches every 2 weeks.
Old 04-24-2013, 09:22 PM   #8
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
if you think the clutch is dead, put the car in 5th gear at 35mph.
floor it.
if it doesnt slip, the clutch is good
if it slips, its dead.
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 04-24-2013, 09:33 PM   #9
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
You should be fine, people drop the clutch all the time to race, once or twice shouldn't hurt that much
shu5892001 is offline   Reply With Quote
Old 04-24-2013, 09:38 PM   #10
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
You don't lose torque nor do you lose acceleration from a worn clutch UNLESS it's slipping. If you don't notice any slippage it's all in your head.
Subie is offline   Reply With Quote
Old 04-24-2013, 09:54 PM   #11
was385
Really sounds like you're just getting smoother with your shifts.
Old 04-25-2013, 10:14 AM   #12
Jakeedaman21
I will try the 5th gear test, but the more i listen to you the more I think it is just a combination of being worn in, and the altitude change affecting acceleration.
Old 04-25-2013, 10:46 AM   #13
whtchocla7e
Drives: 2013 FR-S Hot Lava
Floor it at 35mph in 5th?
That seems like too low RPM even for normal driving, nevermind flooring it. I'd be scared
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 04-25-2013, 11:37 AM   #14
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It's not something to do every day or randomly, it is done specifically to put a lot of load on the clutch. If it holds that much load, it shows that its still working. If it can't, then its done.
Nothing bad will come out of it, its just a quick test
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 01:32 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
