View Poll Results: What level do you refill your tank
half tank 4 12.50%
quarter tank 14 43.75%
dont worry about it 14 43.75%
Voters: 32. You may not vote on this poll
Old 03-15-2014, 02:46 AM   #1
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Arrow Re-fueling Timing and Amount
Maybe this is being over cautious, but when do people normally refill at
1. half tank
2. quarter tank
Also, does it do any harm to pump extra when the pump kicks off telling you the tank is fullÉ
Chad86 is offline   Reply With Quote
Old 03-15-2014, 03:02 AM   #2
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
I usually fill my tank when I'm below a quarter.
Here's a thread about "topping off".
http://www.ft86club.com/forums/showthread.php?p=1568433
eSOLOR is offline   Reply With Quote
Old 03-15-2014, 03:27 AM   #3
Creole
Creole's Avatar
Drives: Monogram FRS
Check that thread out for topping off, it has some good info.
I refuel everytime I get to half a tank. Except for my first tank, I waited till that one got to "E"
Build Thread:
Creoles Creation
Creole is offline   Reply With Quote
Old 03-15-2014, 07:06 AM   #4
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
After the little light comes on.
ntron1 is offline   Reply With Quote
Old 03-15-2014, 08:11 AM   #5
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Why, oh why would anyone fill up a half full tank? Unless you're going into barren wilderness with no gas stations, and in that case you may be in the wrong car.
In urban areas with plenty of gas stations I refuel when I'm almost empty, usually 30-60 km after the light comes on.
Old 03-15-2014, 09:32 AM   #6
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
A quarter tank (as shown on the gage) will allow me to make a round trip to all of my farther common destinations. So I usually fill up when I get a bit under a quarter tank to insure that I won't have to stop for a refill if I'm pressed for time.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 03-15-2014, 10:10 AM   #7
Chad86
Chad86's Avatar
Drives: Toyota GT86
Got it, to clear out the crappy fuel from the dealer. I'm going with Chevron 94, what are you fueling with?
Old 03-15-2014, 10:12 AM   #8
Chad86
Chad86's Avatar
Drives: Toyota GT86
This is bad for the fuel pump...
Old 03-15-2014, 10:14 AM   #9
BobRickel
I fill it till it shuts off and it always reads full. There is a warning sticker on my FRS gas door that says to never try to put additional gas in after it kicks off the first time.
BobRickel is offline   Reply With Quote
Old 03-15-2014, 10:25 AM   #10
Captain Insano
Whenever I get to half a tank or below I fill up on 93 octane when I have a chance. Not all gas stations around here have 93. So I'm paranoid I will be trapped somewhere when I'm low and only be able to run 91 octane.
Not saying it's right, that's just how I do it.
Old 03-15-2014, 10:27 AM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I have never seen or even heard of a fuel pump failing because of running the tank low. The only downside I know of is that you can pick up sediment into the fuel filter, but again, I have never heard of an actual issue with this.
Old 03-15-2014, 10:44 AM   #12
Creole
Creole's Avatar
I'm actually using shitty shell v-power 93. Maybe I should start using chevron 94 lol. I'll have to find it though. I see shell gas stations pretty frequently, more so than chevron. Unless I'm just not noticing the chevrons.
Build Thread:
Creoles Creation
Old 03-15-2014, 11:38 AM   #13
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
That's just superstition.
Old 03-15-2014, 11:50 AM   #14
ntron1
Sarcastic Bastard
Opinions vary...We'll just agree to disagree.
High-G Cornering Fueling Solution EAGLE5 Tracking / Autocross / HPDE / Drifting 24 02-22-2017 08:04 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
Screencast: generating fueling error charts with yike's spreadsheet jamesm Software Tuning 4 12-19-2013 09:44 PM
Ohlins R&T max amount of low (front)? OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-06-2013 06:28 PM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
